Sure.Hey Geo. Can you give us new guys a run down of your modifications? After 50 pages it is hard to keep track...
Thanks.
Cooling system:
-Derale 13960 Hyper-Cool fan-forced transmission fluid cooler, mounted below the front bumper and plumbed in series after the fluid-to-fluid cooler in the radiator, wired into the fuse block using an add-a-fuse adapter on an unswitched circuit. Factory air-to-fluid transmission cooler deleted.
-Cold Case GMT569A aluminum double-row radiator. Had to clearance the top corner mounting brackets a few mm to get it to fit right. Also had to put a small restrictor in the small hose that runs from the radiator to the coolant recovery tank (I used a small brass fitting with a hole through it from the Dorman rack at Autozone that fit inside the hose snugly). I also had to trim the plastic factory fan shroud to account for the greater thickness of the Cold Case radiator.
-New GM 700w fan motor and matching blade from the K5L cooling package, installed in the driver's side fan position only.
By the way, I only just got the 700w fan motor and blade installed last weekend when I had the radiator out for the cam swap and that thing is noticeably louder when it kicks up to high than the 500w motor and blade it replaced.
