alpha_omega
Michigan
If you drill a small hole right at the point of the crack, that should prevent it from growing
Any risk of it “spidering”? Are you thinking a right angle drill / Dremel tool, or is there be enough space for an standard drill/impact?
Just Fishing
Can't fix stupid
Utah
As for teh hoe.
I worked long hours last night, replaced all of the mains after doing an oil flow mod to the thrust bearing...
On the thrust surface on the crank, i took some oil soaked sand paper and did some smoothing.
Did my best to do a mild cross hatch.
Started with 600 and went up to 2000 grit.
The crank is not great this go around.
And i can't get an oem replacement right now.
Best i can get is a used crank...
I also found that you cannot remove the rear main bearing with the rear cover in place.
I might be able to modify it to allow removal, but then I'm cutting into the sealing surface on the pan.
So the rear bearing is slightly tighter than the rest...
I don't think it will matter much, but i have this image of the crank sitting in there slightly crooked in my mind. lol
We are talking something like .0002 difference
Anyways i cut up my hands pretty good last night working the crank.
I'm feeling "ok" about the cranks thrust surface...
+ the extra oil flow for the thrust bearing and loosened bearing tolerance should make good use of that high flow pump.
Overall the bearings look pretty good, the worst looking ones shared the oil flow path with the bad thrust bearing...
4 more rods to go, then i can start the tightening sequence.
Yay...
Just Fishing
Can't fix stupid
Utah
Nice work. Best of luck.
I can see you thinking about that crank being crooked all damn day until you end up taking off the rear cover and fixing it. I have ocd as well…some people just don’t understand. Ha!
Yeah, in my head it's how much money i spent to have this thing perfect.
:jester:
Just Fishing
Can't fix stupid
Utah
and i'm thinking about buying this, do an external filter before the oil coolers.
:hmmm2:
at a minimum, it will give me some more locations to do a pressure check and prevent clogging up the oil coolers....
Saw someone's thread where they installed one under the front plastic skid plate.
Seems like a perfect location to me...
And it would give me a reason to break out the ol rivnut gun again... :cool:
St. Louis
:hmmm2:
I installed a remote trans filter to the inside frame rail just in front of the engine under the splash shield.
If you plan on doing this for the engine oil on the oil cooler line you could probably mount it on drivers side near the lines.20200809_155114.jpg
Just Fishing
Can't fix stupid
Utah
That's what i'm thinking.
for the transmission, i believe the cause of my thrust bearing issue was some metal i found in my radiator transmission cooler.
Thinking if say I damaged the transmission pump, or something about the new converter...
then it's good insurance to prevent future clogs from confusing the hell out of me.
:yaoface2:
For engine oil cooler side,
From what I saw in the pan, the engine oil cooler plumbs after the filter.
Is that correct or do I need to re-review the fluid path?
08z71bgm
Long Island, NY
As for teh hoe.
Yay...
Cannot believe you’re doing this while it’s still in the truck. Lol
Codered5557
