Which build months are safe from lifter problems?
wsteele
I just bought a 2021 Yukon AT4. The build month is 4/21. Is this "safe" from the lifter problems? I can't find official communications regarding which build months had the lifter problems.
Thanks!
GM issued a directive that guides actions under warranty by build date (truck build date). But that is just to give the dealer guidance on the required work if a failure occurs.
The actual cutoff date for bad lifters being installed in engines is March 5, 2021. Engines assembled before that date may have faulty lifters. The actual time delay between an engine being completed and the truck it is destined for being "completed" can be quite long (but I think normally is within a few weeks, hence the 3/31 cutoff in GM's warranty work directive).
You can see the actual engine build date by looking up under your truck at the back of the engine, on the drivers side. You will see a white sticker with a letter code (what plant it was assembled in), a 1 or 2 next (first or second shift), then a Julian date of the year and day it was assembled, the rest is the sequence code.
All of the above was posted on another forum by a guy who works at a GM engine assembly plant. He explained the faulty lifters suffer from the failure of an internal spring that locks the lifter so that cylinder is in fire mode. When the lifter pin lock spring breaks that lifter's valve will not open and you get a solid misfire in that cylinder.
He also explained that the suspect engines are also subject to faulty valve springs being installed (also due to improper heat treating), which explains the bent push rods on some engines (valve spring breaks, valve drops down into the cylinder where it it impacted by the piston and sent back up and eventually to a pushrod that is lifted by the cam and lifter in that cylinder on the opposite cycle stroke for that valve, bang, push rod does its job and bends minimizing other damage. Some speculate that this sequence of events can also cause a DFM lifter failure (due to the force of the push rod impact), I have no idea if that is correct or not, but it does sound plausible and would explain the "found: bent push rod and collapsed DFM lifter" report.
Micahsd
That’s a great post that you found.
Anyone else try finding that white decal? Attached is what I found under mine but it looked like it was attached to part of the frame. If that’s it, I’m not seeing a Julian date listed on it…I kinda suspect that info is related to the frame and not the engine. It’s interesting that decal does show Feb 2021 and my build date shows 3/21 on the door (exact build date according to the dealer is 3/19/21).
I also found some stamped numbers into a metal area near to the left of the oil filter.
Attaching both photos…if someone finds the correct decal please let me know where the exact location is. Thanks.
wsteele
That unfortunately isn't the label. It is fairly short and wide. It is on the back of the engine block. You can barely see it, you have to look up past the drive shaft that goes to the front diff (on 4WD) and you will just see a peak at first.
wsteele
Here is a YouTube clip the guy posted to show how to find the date label.
Micahsd
Thanks…that’s a fun time hunting for that. :)
I was able to find it. I studied it pretty good and typed the numbers into my phone while under there as I couldn’t get a good enough photo of it taken.
The decal did have L84 on it which is the engine code…below is the info. That third row was hard to read.
CU
L84
210424201
K2210421C
Guessing the 042 in that indicates the Julian day in 2021 which is Feb 11th so it’s only a matter of time before I’m stranded somewhere. :(
wsteele
CU
L84
210424201
K2210421C
You are unfortunately correct in your decode, I understand how you feel about the results, but the good news is the actual percentage of bad lifters, within the "bad lifter" engine build window is still really small (I will ask my guy the next time I see him if he knows what the percentages are, but I honestly suspect it is single digits).
Another bonus is when I worked in a factory (so long ago it would be considered pre-historic), second shift was always the most productive and always had the best QA numbers. Yours was built on the swing shift. :)
Micahsd
I hope you're right about the small percentage.
lol on the 2nd shift...that gives me a little hope. :)
Thanks!
wsteele
Thanks!
Best of luck, I think I know exactly how you feel.
Heck, my 6.2L AT4 was built many months after the window closed and I still look for the CEL every time I drive her. BTW, I do the same thing when I am driving my bought new 2007 Yukon. I never did that until I started reading about these lifters on the Internet. The echo chamber can be deafening at times. ;)
Norm 427
Spokane, WA
I pressed my GMC service writer to hazard a guess as to what percentage of Yukons have the dreaded failures. He guessed 5% for the 5.3L and 10% for the 6.2L.
He emphasized he was guessing.
Micahsd
That gives me hope the thing will hold together. Thanks for the info.
brucesmays
San Antonio, TX
My 2021 Tahoe was produced in October 2020. Yesterday at 17,256 miles, it started stalling out when stopping in traffic. Then warning dialogue box popped up saying Forward Collision System Unavailable. Check engine light started flashing. Then another dialogue box saying Service Traction Control. Then dialogue box saying Service ESC. Then all dialogue boxes stopped and the flashing check engine light went off. Then a few minutes later it all started over again. This time check engine light stayed on. Dealer says it is the lifter failure issue. Thankfully they have all the parts in stock.
Micahsd
That sucks, but good you don't have to wait for parts.
Is that the first time that's happened? I don't think I've seen anyone on the forum with that many miles on their '21 that ran into the lifter issue.
wsteele
I would press them to change all 16 when they are at it. My dealer now changes all 16 anytime a truck that was produced in the bad lifter window comes in with a collapsed lifter. They had a fleet customer that had a batch of trucks produced in that bad lifter window. They learned the hard way that an unacceptable number of trucks where they only replaced a single bank’s lifters came back for a replacement of the second bank, usually within 10K miles.
I have read GM’s guidance was to replace only a single bank for any truck coming in with a bad lifter, if it had more than 8K miles on the clock.
I have read that GM is now having the dealer replace all 16 lifters on any new truck they get that has an engine that was built in the bad lifter window (before 3/5/2021). If GM is willing to do that for this issue to go away once and for all, they should be willing to do that for anyone who has a single lifter failure on an engine built in the bad lifter window. At least that would be my argument with the dealer if they balk at replacing all 16.
Best of luck.
Stbentoak
Anyone want to hazard a guess how many engines were produced between Oct 2020 ( or before?) and 3-5-21?
TrueAt1stLight
Minneapolis
I’ve got an interesting slight shudder developing at idle which I’m curious is the start of another litter issue. I’ll be taking it in on the 28th and reporting back here what they find.
Hobert
Downers Grove, IL
Here is the volume they need to keep up with the assembly plant. 182 days X 1200 vehicles per day = Approximately 218,400.
I over estimated, begin 10/1 stopping at 3/5 155 days 186,000 units (assuming full advertised production of 1200 units per day)
wsteele
It is pretty unlikely that a collapsed lifter would just produce a slight shudder at idle. When they collapse, you get a hard miss in the affected cylinder, CEL and any number of other dash lights and messages like Stabilitrak off, etc.
TrueAt1stLight
Minneapolis
When I had lifter failure at 12,995 miles, I had a very slight shudder in the engine when coming down from highway sustained speed. The vehicle almost felt like something spun around the driveshaft. It then operated normally for the next 15-20 min then all hell broke loose as I rolled in to town.
I’m convinced something’s wonky with my engine after the repair. Curious if the lifters are just beginning to fail or if it’s something else.
enigmaspeed27
