2019 Yukon Transmission Cooler options
topaq
Has anyone put on an aftermarket trans cooler on a newer Tahoe or Yukon? I have a 2019 Denali 6.2L with a "CombiCooler" radiator that has the portion for the A/C radiator and a portion for the trans cooler. Looks to be pretty large, especially compared to the little ones in the older models. Still, I have problems with the trans fluid getting pretty hot while towing my trailer up the mountains. Was thinking about a separate cooler such as a TruCool or Mishimoto but after seeing the size of the cooler that I currently have I'm not sure it would provide much inprovement. Maybe adding fans in front?
Jeff_
Scottsdale, AZ & N. Idaho
I don't know if your transmission has the thermostat like the 6L80 does, but if it does, flip the pill in it. My transmission runs so much cooler now with normal driving. And even towing 5000+lbs going up and over large mountain grades, the trans never goes above 180 now. Prior to the pill flip, it would get to the 190's just driving to Costco and back home, and then 210 in traffic.
Other than that, sorry - no personal experience with coolers.
you can fit a trucool in, it's tight but will work, you will just have a trim a small piece of the shutter blade so the cooler will not interrupt the shutter movement
the lines can be ran through the trim on the passenger side this will require drilling a couple holes in the plastic, if you want to use the trucool in series with the oem cooler then you will need to make a small pipe fitting I just used the piece I cut off the oem line and used a flare tool on it.
I made a few notes about in my build page 25
This ^^^^
You can put the biggest cooler in there and if you don't flip the transmission thermostat, it's still going to run at 195. Quick job, easy peasy and the price is right too!
Rygrego
Mission Viejo, California
I added a Mishimoto Trans cooler and love it. It is by far the most perfectly engineered cooler on the market. Totally plug and play with no extra parts to buy. It's not cheap but it is unbeatable. With the pill in the trans thermostat replaced with the pill that comes with the cooler the trans temp rarely goes above 150 degrees.
Tonyv__
Bucks county PA
This ^^^^
Is flipping the pill simply pulling the thermostat out and flipping it upside down and reinstalling?
And if so, is this for all 6l80s for just certain years? Both my van (6.0 and 6l80e) and Denali (6.2 and I think 6l80) are due for trans service within the year. I want to do this to both of them
Jeff_
I believe 2015+ 6L80's have this thermostat. And yes, just take it out, flip it, and put it back in.
That way it forces the fluid to circulate and stay cooler.
f16z28
Do you have the part number ?
tuffguy23
You might need to update the transmission cooler thermostat device. Here is the GM TSB that shows the change that lowers the temp from about 190 to about 158. Mine runs about 160 all the time.
  • TRANS_THERMAL_BYPASS_TSB.pdf
Laurents10
