Figured out how to keep steady voltage
09_4WD_YUKON
grounding the headlights to the frame may be your solution then, don't cut your factory harness just add a ground to a accessible clean spot on the frame as close as you can. use a multimeter and check to be sure you are grounding the ground wire on each side don't take it for granted that the same color wire is the ground on both sides I have seen them reversed before just a little heads up.
Yeah, but the headlights dim due to voltage dropping to about 11.5 (per the gauge). I put some LED headlights in last night and notice the voltage dropped to 11.5 (on the gauge) but they did not dim. So good for now. Is there a way to turn off the RVC in a tune or something? I tried unplugging it , to no avail. I plugged it back in and all is good...for now.
so I take it you did not try grounding the headlight negative wire to the frame? if your voltage is dropping to 11.5 then you have either a weak battery or weak alternator or both or bad grounds or all 3, these trucks are well known to have ground issues. when voltage starts dropping the first thing I look at is the battery, I just had one replaced yesterday, it started the truck just fine but I would get a low battery warning within a couple minutes if the door was open, etc. in the past I could always tell by the volt meter if it was moving even a little I knew the battery was getting weak it's a tell tale sign, now it's more or less a guess by how it starts or if the warning comes on
Trucker186
My cruise control wont work if it drops below 14 volts not sure what to do. Its the 5.3 V8 i think it might be this sensor.
09 Chevy Tahor LTZ
BG1988
I still have issues every once in a while. But mine come from my air ride compressors coming on at the same time my truck starts and that's the same time my auto-headlights come on. That's just so much strain on the electrical system at the beginning and all at once.
As long as my compressors aren't on, there's no issues at all
you should put a 16v bank Maxwell Ultra caps as well to buffer the compressor
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
I unplugged this and it is running great.
Tahoe14LTZ
Is it smarter to upgrade the stock alternator? or to run a 2nd battery? I have a friend who ran a second battery and kept the stock alternator and hes got about 4000 watts pulling, and he said it no longer dims his lights etc...
camaroz2887
Nj
Noticed somethin interesting this weekend. I hand unplugged rvc 10-12 months ago and got the benefit but never disconnected the battery(lazy). It would stay at 14v on the dot unless I got a bass heavy song or the ac was on with the stereo.
Figured the batteries got some age to it and the stock alternator was prob gettin to the same place and is not much higher of an amperage than the amp draw by itself. That is, until Sunday.
Decided to do the motor mount, got it all closed up and realized I had pushed a wire up over the steering shaft before re-installation. After a slew of profanity i found the wire had a connector close by. Disconnected the battery then fixed the routing and reconnected the battery.
Now it’s getting a steady 14.4 volts on the heavy songs (Haven’t tried ac yet) and never batting an eye at it. Hopefully this stays and isn’t a fluke from essentially clearing the memory.
Moral of the story... don’t be lazy!
EvergreenZ71
Firefighter EMT/First Responder
Washington
Anyone still running this mod? I’m running a stock radio but have installed a Scoshe GMQ01 MagicMount wireless charger. Unfortunately it is designed to only charge at 13+ volts so it doesn’t stay on while parked. But today during a long freeway drive we spent the majority of the drive at 12.8-9 volts making it useless.
ideas?
BG1988
mine is dropping to 11.7 when off it stays charging at 14.6-14.7v (shown on mutimeter) 100% of the time should i take it back to walmart still under warranty it went from 12.3 to 11,7 in 2 days
it has the full 5 year warranty i'm only 2.9 years in
what type of battery is it? i.e. agm/standard
Midnight_Yukon
on the 07+ we have this regulating system (Regulated Voltage Control or RVC) that basically controls the alternator when it sees more/less drain on the battery.
Being that I have a decent sized stereo as well as HIDs (with the relay harness) on my truck, I looked for a way to turn the RVC off. There would be points while driving that my HIDs would start to flicker because the ballast weren't getting 12 volts. I thought it was the ballast and swapped sides and even purchased new ballast with the same results.
Well, there is a wire connection on the negative side of the battery that controls this system. If you unplug it, your alternator will continue to charge and will stay around 14v while driving. I've had this unplugged for almost a month now with no issues what so ever. No more stereo drain, no more flashing of my HIDs, nothing. I haven't seen any consequences of disconnecting it either.
Here's a few pics you can see the plug and the wiring to disconnect. I put some electrical tape over the connections so they don't rust or get corroded or anything.
photo1_zps344fc5e0-jpg.178079
photo2_zpsf1ecbf11-jpg.178080
photo3_zpsabf70b3f-jpg.178078
I’ve got an issue with my headlights flashing aswell as my dash and stereo system and basically every light on the inside. I have underglow but it’s not even on the battery or plugged in currently and it’s still flashing could this help?
robgreg75
Yesterday on my wife's drive home the battery light came on, I checked it with my multimeter and it was overcharging at 15 volts all the time. I found this thread so pulled this plug and it fixed the issue and the alternator dropped down to 14.5V and the warning light went away. So this can fix more than one issue. Also I will say this 2010 goes through a battery about every 3 years I wonder if the weird factory charging had anything to do with it.
chevreb
Hello, new to this thread but not automotive. Would this RVC cause an alternator to spike about 15.0-15.3V when running?
RooTBeeRthe1st
Sub'd
When idling in gear and a/c on full blast at temp(700w fans going ham), voltage drops to 11's and sits there. Rev it at all and jumps back up to 12.5+ as it should.
Just pulled the ammeter sensor plug like in the OP, we shall see results tomorrow.
Sub'd
I went thru all of that myself and more and in the end it was a defective battery, it was just barely good enough to pass a test and not get warrantied. So I bought 2 brand new batterys and that was about 2 years ago and no problem since
RooTBeeRthe1st
I have two yellow tops in it. ones brand new, ones maybe 2-3 years old but still good condition.(was my only good battery for quite a while.
figured id try this first.
but i think my alt is starting to crapout.
still need to do the big 3 either way.
had bad alternator before that as well, was a ebay special actually 2 of them, then i got tired of it bought the mechman
RooTBeeRthe1st
That's why I was thinking I would just jump straight to a higher output alternator I have to replace it anyway.
200-250 should be plenty for me.
RooTBeeRthe1st
Well, now when the fans kick on high, it drops to 12.5v and holds.
I can live with that, but I definitely want to do the big 3 and see where that gets me. Then a new alt to top it off.
All that said, I still haven't gone in for my fan or airbag recall.
So maybe the fans are pulling more than they should be.
a1parrothead
