madmanjustice
I have the GoRhino pushbar. I couldn’t find a complete used Setina piece, and new ones were not available.
i'll probably end up with a Go Rhino on the 2014 since (as you say) complete Setina units are hard to find and Setina does not sell parts directly to consumers. I had to buy two used Setina bars to get all the parts for my PPV.
Sparksalot
Bastrop County, Texas
Mine is a 5000 series. They also make a 3000 series. Appearance is similar. I learned waaaaay after the fact that the major difference is the 5000 series is rated for impact. Perfect for deer armor.
Fubar0715
Scott
Southern New Hampshire
I have been pulled over years ago for no front plate. I may run without it and take my chances...
New Hampshire runs front and rear plates. Still haven't installed the bracket on wifey's Equinox and I absolufreakinlutely refuse to put a hole in my Mustang front bumper-write me the damn ticket! :sorrysign:
Kee Fuller
las vegas
Arrg. Discovered the front bumper on my 2014 is not drilled for a license plate. And in Texas a front plate is required. So when i get my plates I get to drill into my nice smooth bumper to install my front plate. :nolol::biggun::killer::Jedi::Rant:
I got a ticket on 45 coming home from college for dark tint and a vanity from plate.
It was my rims too. The stop was hilarious. Judge threw it out.
Bigkevschopshop
Northside H-Town
In my area, they don't enforce the Plate on the front rule... Too much other junk to bust peoples balls for...
Northside of H town...
Just Fishing
Can't fix stupid
Utah
Here, it's a matter of they can pull you over whenever they want.
Wifes car doesn't have one.
PO replaced the bumper cover and opted to not have it drilled for a plate holder.
I did buy the plate holder, but it needs to be painted to color match the car.
Then i ended up building a new engine for the hoe, it has been on the backburner since.
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
On the Go Rhino I recommend drilling drainage holes in the lower cross bar to let the water to drain out. Also grind some drain notches in the ends of the tubes because they are capped concavely and hold water there as well. If not rust streaks start to run out of the mounting bolts and streaking down the side plates and looks like ****. Just a heads up. I have not had an issue with the top tube yet.
89Suburban
SE PA
I ran into the previous owner of the Hoe today at work. He says my trans was replaced at around 150K. So that means I got about a buck 80 on the current one. So at least I know now it's not the original. And hopefully built up a bit with better ingredients.
Sparksalot
NOW you tell me. Also a true story.
89Suburban
SE PA
Sorry saw some reviews here and there about it and took a shot. Apparently they are not painted on the inside. I saw a few reviews complaining about this.
Bill 1960
Testing the Limits
Which one did you go with?
OEM. Taking the path of least resistance and fastest. I’m lucky to get it into a shop on short notice; every place I have been all summer is backed up, and this town is no different. Every shop is surrounded by a pile of vehicles waiting.
Except for the dealers, who have empty lots, and still give the same answer EVERY time, which is 1 week backlog for the shop. I think it’s GM policy or something. But they do seem to be short handed.
I may change out all the mounts for something stronger when I’m home in my own garage. This winter I need to decide whether to fish or cut bait. Which means proceed with winch, axle upgrades, lockers and all that… or maybe upgrade to a 2500 and build that.
I need to look into the specs on a 2500 Avalanche which I think is probably as long as a Suburban.
kbuskill
NE. FL.
Avalanche is the same as a Burb.
Korbin_A
