blueinkd
Oh, wait..... ( My Bad)....... I just noticed, it's the Key that broke......
Contact the manufacturer and have them send you a half-dozen keys... For free...
He needs to do like me and spit on the wheel lock and slide the key in. Comes right off!!
I panicked when these did the same...
It's not the key. It's the inside part of the pattern on top or the wheel lock. Just like mine
Yeah it looks like the key should still work, just might not be as good of a grip with the inside gone. Worst case, use an impact so it doesn’t slip.
Sam Harris
Looks like mine!! My keys still works though. Have you tried it ro remove them?? Mine been broken like that due to not being long enough ad as confirmed by McGard. I been meaning to order the longer ones but after breaking like yours they work just fine
So, 1. What’s the part number for the deeper one?
2. Does this seem to match your OEM set..? It seems to be super crap metal. And way to thin to holdup to the torque spec in my opinion.. am I off base here..?
Just comparing to the aftermarket set I have now (Gorilla), there’s a massive difference in metal purchase. I mean I know it’s a different design, but seems the “OEM” set I bought has a very, very thin spot that’s supposed to holdup to the torque..!
Sam Harris
Did you not try just the key??? im glad you got them off though!!
I did not TBH.. I was worried about it slipping and damaging the wheel. I’m glad I got it. It’s possible I could have with the key, but the damn thing is so shallow to begin with, I actually was worried about it slipping while I was I was installing, before it broke. Just seems like a crap design to me. Maybe these actually are OEM…!?
blueinkd
I'm with you. Earlier in the year I had the same issue. McGard makes quality wheel lugs and locks. My issue was overall lug length. They referred me to the correct ones when I complained!! After I gave them the part# I bought from Amazon. Which part # did u buy??
blueinkd
Also discovered today that the “Gorrilla” wheel locks I like a lot don’t really make a lot of contact in / on the wheel, even though they are the correct, conical style. So I went looking for the proper wheel lock set for the ‘15 GMC wheels I have.. part: 84488348 for the GM OEM / GM Performance part. Looked on Summit Racing, and almost dropped the $80 on that, until I saw it wouldn’t ship until mid-November.. Ebay seller has the genuine, new part for $30.37 shipped. Hell yeah! Hopefully it’s the real deal. Any tips how to verify are welcome. View attachment 349995
These are labeled 2011-2021. I'm sure they are not long enough to accommodate the longer wheel studs on our rigs.
Sam Harris
I didn’t realize our rigs had longer studs. When I installed the OEM ‘15 wheels on my ‘03, I also ordered the ‘15 lugs for them. Those have worked perfectly, but I obviously have an issue with the ‘15 locks.. so you’re saying I need a deeper socket for the lock..? I’ll buy that. But does that amount of material (especially considering it’s apparent lack of quality steel) seem sufficient to hold 140 ft lbs..?
Sam Harris
I bought part #: 84488348. I still say there’s very little steel to hold that torque, even at the correct length.
Regardless of the metallurgy, the marks on the tip of the stud and the fact that it even contacted indicate that the nut was too short. I'd get deeper nuts or trim the tips of the studs some.
I bought McGard 24215 in chrome for my Silverado and 24216 in black for the Denali. They’re listed as 1.965” overall length. Both sets work great.
blueinkd
All i am saying is that the specific set you just used does not list our year trucks under the application chart. Those locks are hitting the top of the wheel stud before seating all the way into the wheel. I dealth with the same issue earlier in the year when Mcgard customer service pointed that out to me. I picked up a set from Amazon with the correct thread pitch but too short, so now im riding around with broken locks like u saw in my picture.
blueinkd
this is weird as the Mcgard website specs both of those at 1.639 overall length??
Funny thing is my locks have only broken like that on the front studs. I have Moog wheel Hubs up front. the rear ones are just fine and have yet to break off.
You're correct, I'm not sure where I got 1.965. They're long enough to not bottom out but I am running reps and billets, no stock wheels.
Woned2004
