915_Tahoe
Your GM Parts Specialist
HELL PASO, TX
The thing about it was I already had the p/n for 99% of it.
Here is the real kicker.
Front coil springs p/n 20842473
(last 8 BR245859)
So what to do next considering none are available. Only two show up in the whole country (MO and NC) - I called and both are spoken for. Also, there were no other p/n’s listed which superseded them nor any others for cross reference.
Does anyone who lives further south or anywhere things dont rust have any local LKQ/yards they recommend for a set of front coils?
I have all new struts, mounts, hardware, insulators…etc so the options are:
1. Try finding a different coil that fits without throwing off the feel of the ride.
2. Try to return the newly purchased struts and all of the hardware, then look for an aftermarket set?
3. Buy a pre-assembled unit that isn’t cheaply built.
Any suggestions gents? I have no need to lift the vehicle. It could potentially be lowered, but I would have to adjust the rear as well so I don’t end up with the “Carolina lean”.
There is a GM#88875301 Coil Spring set.
(Constant rate spring, w/ Electronic Dampening control suspension).
2 dealer shows to have this set.
Chicago Parts and Sound, LLC
(262)781-7180
Elk Grove Village, IL
(888)781-7180
Brookfield, WI
I don’t think that option (GM OE) is going to be available for me. Not unless I use a different GM part.
I wish that were the case…see attached photos
I have a stubbornness that’s usually unwilling to ask for help. If those options of just ordering the new parts and slapping it in there were available I wouldn’t have reached out. OEM is really the only way to go especially given the ride of the Denali, but the lack of coils springs is the issue.
I see the photo's now, that being a pretty rare case, if new is not readily available I would just go with a used set and install new shocks, looks like some sort of metallurgy issue
I'm a little late to the party here, what exactly are you trying to accomplish? Replace the springs up front?
the_tool_man
Upstate South Carolina
It might be convincing if you’ve never had the real thing before. I had a Harley Davidson V-Rod with all CF body parts. The stuff looks amazing. The wrap? It looks like a picture of CF. It looks better than the fake wood but it’s nothing close to real carbon fiber, which has depth. It is expensive though.
Fair point. I've never really looked at "show quality" CF. I'm comparing to more utilitarian stuff I've seen (and made a lifetime ago).
RooTBeeRthe1st
Sadly, Amazon beat the crap out of summits delivery time. The only thing I'll have to check is the date they were made. Summit was getting me some direct from the factory so I know those would have been brand new.
Never been so happy to see a UPS guy. Haha now I just need to get off of work.
Looks like oil change and new tires happening this weekend.
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
Yu install those yourself or take them somewhere?
Pictures don’t do it justice, it’s 3 dimensional. You have to see it in person. At one point I needed a matching headlight cowl because I changed things on the bike and at first I tried having one hydro dipped but it looked despicable next to the real thing. Luckily I found a company that was making them.
RooTBeeRthe1st
Definitely more aggressive tread.
Including the sidewalls.
Turns out, tires are a lot shorter after 50,000mi.
Dated only a month before my original purchase date. (first week of may)
Already cancelled my order through summit.
a4edwin
ny
Pictures don’t do it justice, it’s 3 dimensional. You have to see it in person. At one point I needed a matching headlight cowl because I changed things on the bike and at first I tried having one hydro dipped but it looked despicable next to the real thing. Luckily I found a company that was making them. View attachment 349218
I would like to see a pic of the whole ride!!!
Just Fishing
Can't fix stupid
Utah
I had some POS at work that got fired slash all 4 of my tires because I was the last manager on duty even though I had nothing to do with it. Karma is a ***** though. He is pushing mushrooms out of the ground last I heard.
Guy that messed with my vette died recently.
I still don't know what happened, but from what i read they are cremating him cleaning him with fire and spreaded his ashes a few weeks ago (or maybe that was a few weeks from now).
Wife i think will let me know when i can start jumping up and clicking my heels, and doing little dances and making up songs.
For now i have to be "I'm sure he is in a better place" (with fire!)
(lord forgive me, I know it's too soon to poke fun at it :banghead: )
Just Fishing
Can't fix stupid
Utah
So while on the subject...
I kept thinking about my tahoe
and the weird material, that's nearly identical to the last engine.
Thinking "if", then "how"?!
I looked pretty solid at the hood latch, and noticed it looked like i could pop it with a screw driver.
So i tried.
Yup!
Stupid easily.
alarm seems to only go off if i lock it with the key fob.
and one test it didn't go off after locking it with the keyfob.
More testing is probably needed, but i'm thinking it needs a little plate IN front of the latch for good measure.
Other way: oil filter.
but that would take some planning and work to not leave a drop in my driveway.
And something i could see him doing...
anyways...
While my problem solved itself...
Bill 1960
Testing the Limits
Tonight’s latest development was a click-no-crank after hitting the car wash. I did not clean under the hood, but I did work ******* the wheel wells to dislodge a bunch of hard clay.
I could hear a loud click at each attempt, but no crank. Raised the hood to let it dry and spent a few minutes looking for an implement that I could use to bang on the starter without laying in all the wet mud under it. Cranked on the first try after a 3-5 minute wait. Never touched a thing.
What’s the top two suspects? I need to procure and carry spares because if she won’t crank in the outback it’s a big deal. Battery is a new AGM. Cables *look* good.
I‘m thinking starter and starter relay? Although in a pinch as long as the starter is good I can crank it with a jumper cable.
Escalade2007
