Help! 1999 Chevy Tahoe no start issue!
Sammie859
Sammie859
Lexington, Ky
Ok. So I sent it to Goodyear to be diagnosed. All he could tell me was that it was a tac issue? Not sure what that even means. That it could be the ECM? That it was a wiring issue. Which doesn’t make sense. But idk. Any help or advice? Goodyear said it was more than they could deal with.
Sammie859
Sammie859
Lexington, Ky
The injectors are inside the manifold. The distributor is immediately behind the upper half of the manifold that has to be removed. Maybe the tech damaged the wiring going to the cam sensor in the distributor? Or maybe partially unplugged the connector, even inadvertently?
Also, if you've replaced the crankshaft position sensor, it should've had a CKP relearn performed.
What is the CKP relearn? Would that keep it from starting? And how do I do it?
GMT800 2005 Tahoe Z71
Navy Supporting Member
Goodyear shops are mostly parts changers. They don't do well with diagnostics. Find a good independent shop, ask friends, check reviews.
CKP is Crankshaft position relearn. The CK stands for Crankshaft and the P is for position. Have to have running for the steps suggested:
How do you relearn a crankshaft sensor without a scanner?
  1. Turn off all of the accessories.
  2. Accelerate the vehicle to 55 mph at. part throttle. ...
  3. Cruise at 55 mph for another 5-6. minutes.
  4. Decelerate to 45 mph without. using the brakes, and maintain 45. ...
  5. Perform 4 deceleration cycles, ...
  6. Accelerate to 55 mph and cruise. ...
  7. Stop the vehicle and idle for 2.
What happens if I don't do a crankshaft relearn after replacing the crankshaft sensor?
Failure to do such will result in over revving of the engine, causing possible engine damage. 8. Once the engine has returned to idle, check the status of Diagnostic trouble code P1336. If the scanner indicates that the CASE has been learned, the relearn procedure is now complete
Sammie859
Sammie859
Lexington, Ky
Ive not
Been able to get it started since changing the sensor.
wirlybird
Take it to a good independent shop or to the dealer.
On the times my '97 wouldn't start it was one of these things.
Fuel pump. So get the fuel pressure checked to eliminate that.
Bad distributor cap. Unlikely in your case but make sure it is seated correctly.
Are you getting spark at the plugs?
Also on mine the mass airflow sensor had gone bad. This should give a code.
It's when you put the ECM into a programming mode to make it learn the signal from the new crankshaft position sensor. No, it won't keep it from starting as the engine has to be running as well as held at 3000 RPM (I think) to complete the learning process. I was just mentioning it in case it wasn't performed. It'll probably run fine without it, but it'll never be quite optimal. Any decent shop worth their business license should know to do this and include it as part of the CKP sensor replacement. You need special equipment to put the ECM into the programming mode, so it's a mechanic shop job. The shop that replaced the sensor owes you this if they didn't do it. It only takes about a minute.
YukonGTmaster
2 Door w/ Barn Doors Club
I’m sorry you are having such a hard time with this. You said you had the spark plugs and wires replaced. This is a shot in the dark, but…. See if the plug wire for #5 and #7 cylinder are plugged onto the wrong spark plug. It is “Very” easy to install these wrong. There should be numbers at the distributor cap. #7 wire has to go furthest spark plug back to the firewall on drivers side. #5 has to go just forward of that plug drivers side. I usually have to touch the wire and keep touching it as I follow it from the distributor to the plug. Don’t give up!
I have a 99 Chevy Tahoe 5.7. I recently had fuel injectors replaced. When I received the truck back to check engine light was still on. I went to AutoZone and had the check engine light checked. Said it was a crankshaft position sensor code. Oh I change the crankshaft position sensor and also went ahead and changed the spark plugs and wires. Now the engine won’t start. It cranks but won’t start! Battery is new. It’s not the alternator. Mechanic that worked on it said it was a spark issue! Any advice?! Opinion? Where do I go from here?!
So, the order of events is:
1) The check engine light came on, so you had the injectors replaced (did you ever read the code(s) then or you did you go straight to replacing the injectors?)
2) When you got it back, the light was still on, so you went to find what the code was and found that it was for a crankshaft position sensor
3) You replaced the crankshaft position sensor, spark plugs and wires
4) Engine wouldn't start after that
Did you get the CKP sensor from AutoZone and is it their house brand? Do you still have your original CKP sensor?
TheDabDoc
Sounds like a security issue to me if the security system kicks in it prevents the motor from getting spark .I would try to do a reset which is basically turning the ignition over to acc on then back off 5 times
Sammie859
Sammie859
Lexington, Ky
Yes this is the order of events except your #1 I had injectors replaced because I was having issues with it randomly not wanting to start-thought it was fuel pump but shop diagnosed it as 2 bad fuel injectors. ThTs why I had those changed. Then when I got it back. It had the code for the camshaft sensor. So I was going to change that and the crankshaft sensor. (Crankshaft got changed first) because it was broken off. (Never changed the camshaft sensor). so, since I had the crankshaft sensor changed I went ahead and changed the plugs and wires because I’ve had it for a little over a year and I didn’t know when or if they’d been done before and my truck has 220(ish),000 miles on it.
but after changing them (sensor, plugs and wires) it hasn’t started back up! I’m getting frustrated at this point.
So today I called the previous owner (I know him person and he’s a mechanic) to tell him what Goodyear had told me (because he thought it may have jumped time) and the previous owner told me to check the plug to the ECM because it had given him a problem before. (He apparently had sent it to the dealership and they couldn’t even figure it out) but come to find out the plug to the ECM wasn’t in all the way! It just looked plugged in.
so when I pick it up Monday from Goodyear I’m gonna check the ECM plug and also unplug the battery completely to see if maybe it’ll reset something and by the grace of god START! ‍♀️
wirlybird
You mention changing the plug wires. Have you verified the cap to plug order is correct? I am sure you did but this was one thing changed right before the issue appeared.
Verify and eliminate the most obvious and easiest things first.
Gotcha. With all the events and parts that have been replaced, the story can get confusing and mislead the diagnosis. Throwing a bunch of parts at it can bury the root problem, so we gotta know how it was, what was done and the direct result all in chronological order.
So, the plugs and wires were replaced at the same time as the CKP sensor replacement. It's common to get a couple of the spark wires mixed up, but they'd pretty much all have to be really mixed up to cause a no start or to not allow even an intermittent fire ("try" to start).
As @wsteele said- double check the firing order of the wires. You also can't rule out a faulty CKP sensor, especially if it was a parts store special. GMs needs quality parts and the cheaper aftermarket copies tend to cause problems. Whoever AutoZone uses for their bottom-dollar house brand of aftermarket electronics parts has been well documented to be producing some junk.
As for your P0340 code, that's the Camshaft Position Sensor ("CMP"). Since the CMP is in the distributor and this is the area involved when replacing spark wires, I'd check there first for faulty wiring. Did you replace the cap and rotor?
An engine needs fuel, air and fire. I'm sure it's getting air. Fire (spark) is questionable at this time due to your code(s). Once you can rule out lack of spark, then we can move on to fuel.
exp500
The story changes each time we get more info. You are probably not mechanically inclined, but thats OK. We can work with you as long as you help us along.
I asked for a spark check at coil and at Distributor coil terminal, was this done? Results?
Also asked for fuel pressure check results. On this Item- call the shop that changed injectors/spider. They should have done this before and after, at least before. Post the number they give you. Also Gently ask them if they reset the timing after distributor install. (The P-1345 in above posts). That will help to eliminate 2 problems.
Is sounds like problem started after Crank position sensor replacement. Was an AC Delco or Delphi unit installed? If other, that is your first Check. Replace with Delco.
Next step is Spark Check. A spark tester is $10-15 at AZ, so its worth it even if you have to buy it for them.
On having P0340, engine should still start. Crank position relearn not required on this engine- But P1345 must not be present. And a 50 mile drive cycle relearns everything. Keep posting we will get you goin again. Here is a diagnostic that will help your neighborhood mechanic thats helping you-
Charlie21ny
