REAR END UPGRADES
Junior_97
What’s up guys new to the forum. I have a 2002 Tahoe 5.3 flex fuel. Looking for a good rear end to upgrade to, currently stuck with the 3:42 and want something more sturdy. Savage yard finds would be fine. Thanks in advance.
GMT800 2005 Tahoe Z71
Navy Supporting Member
Welcome to the forum from Oregon.
When I saw the title I thought you were searching for a new wife or girlfriend.
Are you talking about just the gears or the whole axle assembly. I had an 02 Tahoe and loved my 3.73 gears.
If you are doing the whole axle, I would use the 9.5" 14 bolt semi float axle. If you have 4x4, you will need to do the gears in the front diff as well. Or just bolt in the 3.42 gear 14 bolt semi float at the rear.
Junior_97
Junior_97
Preferably a new axle assembly. I found a 10 bolt with 4:10 and a g80 locker for 450$ but I was told the 12 bolt or 14 bolt are the way to go
Welcome to the Forum from NH.
Pics of the truck, please.
You are already receiving sound advice and perspectives from the knowledgeable folks on this Forum.
S33k3r
Dallas, Texas
I went with Yukon Gear and Axle. I had an authorized dealer/vendor do it so it would have the lifetime warranty.
Ring/pinion (3.73)
Complete master rebuild kit
Dura Grip limited slip
May I ask how much that ran you?
Go to LKQOnline and look for 14-Bolt Saginaw 9.5" axles (RPO AXN) in RWD Escalades and Denalis (2007-2014), they all have 3.42 gears and G80. Just bought one for $289 plus tax but every area is different. LKQ even warrants it. So you have to tell them yours has a 9.5 with 3.42 gears.
We'll eventually install 3.73s in ours.
Junior_97
Junior_97
Ring/pinion (3.73)
How much did that end up being? I’m kind of on a budget.
Junior_97
Junior_97
Bill 1960
Testing the Limits
Is a rear driveshaft swap required with that upgrade? Usually a bigger diff means a shorter shaft.
Mudsport96
40.923,-89.488. Illinois
The 9.5 is a great upgrade, but my opinion is the 8.5/8.6 is plenty strong for stock to mild power levels. The govloc (g80) is the weak link. Get a good quality posi unit... trutrac, auburn spring type etc, and you'll be fine. I know there is a significant weight difference, but i have a 8.5 in my nova making 400ish at the crank and a 2400 stall converter pushing through a all stock 8.5 with a mini spool and havent hurt it in 10 years track or 8000 street miles.
Nope. Same part number.
Let's not forget that your Nova and my old Buicks weighed less than 4000 pounds in racing trim. We didn't need to beef up our axles until we were knocking on the doors of the 9s in the quarter mile. If memory serves, that was Moser axles with c-clip eliminators but I never even did that.
scottd
