Post DOD Delete engine noises
Darren2014
So just finished up the DOD delete on my 2014 PPV Tahoe. It started after a few extra seconds than normal and ran but it now has a loud ‘clank’ noise coming from the drivers side of the engine. I’m worried that it’s valve to piston contact in cylinder one since that is the general area the sound is coming from. It acted like it didn’t want to go during my test drive. I’d stop at a stop sign then have my foot to the floor trying to get some exceleration from it and barely be going 15 mph. It also seems to have trouble starting now since the test drive some times taking several attempts or taking longer than normal to start. I did see on another forum where a guy had similar issues after his DOD delete and it ended up being that the Cam Phaser wasn’t properly aligned with the Cam. Any ideas would be helpful. I’m desperate to get my truck running smooth again.
wsteele
I wish I could be more helpful, but I only know VVT from the book side of things.
I would be inclined not to run it until I had the problem identified, clanking sounds are not good.
Has it produced any DTC codes?
1BADI5
DMV
I deleted the DOD/AFM and VVT before it started making scary noises. I had a light lifter tick on cylinder 6......so I tore it down and rebuild everything minus the SBE.
1BADI5
DMV
What did you actually replace, we're going to need your parts list to start
Did you correctly set the timing?
Are you getting any DTC?
Whats your oil pressure readings cold and hot?
Has your truck been tuned since the DoD/AFM delete?
We need alot more information to attempt to provide you with a diagnosis over the interwebs.
I did my DOD/AFM and VVT delete about a year ago and its been amazing, I actually get better MPGs w/o that $hit and tuning
Geotrash
Dave
Richmond, VA
Ugh...I had a similar problem after my first attempt at the cam swap. Turned out to be a failed lifter that started wiping the cam, but we never determined the true cause. Sounded like a loud chirp when it was running but the engine made great power. Must be something else happening with yours if it's not making good power. I agree with the others here - time to tear it down. I'm feeling your pain, brother!
1BADI5
DMV
Did everyone soak their new lifters in an oil bath/tub before the install?
I dropped my new LS7 lifters in oil jug with fresh oil for 48 hrs before reassembly
Geotrash
Dave
Richmond, VA
Sure did. Though notably, some of the guys on the ls1tech forums recommend not soaking them and instead just dropping them in oil right before install. No idea why.
1BADI5
DMV
Yeah I was brought up and taught to soak them.
I have seen the method you speak of and I've seen some just apply oil to the rollers and the pushrod cups.
wsteele
I can't imagine soaking the lifters in an oil bath for 24 hrs, 48 hrs, whatever could be a negative. In the end, getting everything primed before the first fire is the most important thing, I think.
D
Darren2014
I used a L9H factory cam, morel 7717 lifters, Acdelco trays, new acdelco crank sprocket, timing chain tensioner, cam phaser, and cam phaser actuator bolt, cloyes timing chain, stock push rods and rocker arms, .550 max lift springs, new high pressure melling oil pump and melling pick up tube, and every gasket replaced with a flepro. I did pre soak my lifters and they soaked for a good 3 days before install. Didn’t intend for that but I couldn’t help my work schedule.
D
Darren2014
I’m really thinking this has something to do with the timing. Very little to no power, and possible piston to valve contact on cylinder one. I’m wondering if the cam phaser is misaligned from the cam and causing my issue. Or if it’s some other issue with the VVT. I’m debating on deleting it at the moment.
wsteele
Maybe consider an inexpensive borescope to see if you can determine if the valves in number 1 are actually banging? You may be able to rent one pretty cheaply or buy a cheap one on eBay. I like the ones that come with an LED on the camera end, helps illuminate dark places.
Maybe a quick and dirty dry compression check also might tell you a lot.
randeez
south florida
did you replace the valley cover and/or plug the dod risers?
and did i miss if it was tuned or not?
and when you say stock pushrods - did you reuse the ones you had or stock for a non dod engine?
D
Darren2014
I did replace the VLOM with a non DOD valley cover. I didn’t plug the oil towers but the new cover came with internal O-Rings that are supposed to keep oil out. And it has not been tuned yet, but the only tune I planned on running was tuning out DOD via HP tuners. For now I still have a Range AFM disabler plugged into the OBD2 port. And I reused the push rods that came out of the engine. They showed no signs or wear.
randeez
south florida
pushrods - i wasnt sure about them all being the same but google seems to think so so maybe not a problem
range wont cut it, tune needs to be fixed. i think someone on here drove around with the vlom plugged in and laying on top of the engine to be able to drive it in the mean time till they could get tune fixed
D
Darren2014
Unfortunately the VLOM got thrown out a week or so ago.
D
Darren2014
And the Range was just s to band aid it to get it back to the town I live in and parked till it could be tuned.
D
Darren2014
I’d look at going the blackbear route but I don’t have a laptop to use for it. Unless I could find a long enough cord to plug it in at my house with my PC.
Geotrash
Dave
Richmond, VA
You don’t need a laptop. A desktop or tower pc will do just fine. The only device that goes back and forth to the car is the Autocal device to record the data while you drive and then apply the tune later.
Randeez is right about the tune, but if you’re hearing significant mechanical percussive noise, I would investigate that also, as Bill suggested. At the very least pull a valve cover and turn the engine over slowly by hand to check for interference. I also have a borescope from Amazon that was cheap as chips and works great. Fits in the spark plug holes to check for damage.
I would also pull the timing cover to check that you got the timing marks aligned right.
I went with a 3 bolt cam because I didn’t want the worry of degreeing the cam right.
D
Darren2014
I actually did turn the engine ever by hand once I had the push rods and rockers in, about 5 times just to insure there was no resistance and to make sure every rocker/ valve was operating.
I know my timing marks were correct when I installed the cam phaser aswell. Everything I’m seeing here leads me to thing the Phaser was misaligned and is rotating on the cam bolt. I think my next step is gonna be pulling the timing cover off and removing the phaser to see if anything is going on back there.
Drewphil
