Lol. Beatings are always an option ….its whether or not it fixes anything
Lol, very true. Beating it is what messed it up in the 1st place. I'm hoping it'll be ok.
Check out the differences in the design of the lower shafts. 20210723_140052.jpg20210723_140101.jpg20210723_163049.jpg
Old shaft is splined. I separated into 2 pieces.
blueinkd
Thanks Tony. My gearbox is a reman unit. What helped me the most was new idler,pitman, idler bracket and gear box. I did all this at the same time and really improved my steering
TheAutumnWind
Dropped new Delco Rad in this morning. Looks like truck was running on OEM radiator as well and it failed at lower driver side corner. PLease make sure you have a decent pair of hose clamp pliers or 2 or 3!!! They are a pain in the rear. i spent more time jacking with the hose clamps than pulling out the rad and fan assembly.
Hmm I should probably replace mine soon as I am still on the original one with 200k+
Which gearbox did you go with? OEM? Who rebuilt it? I hear used/rebuilt is a gamble.
ivin74
05 NBS Nali
Htown, Texas
The best gear boxes are the redhead or blue top, the autopart store gearboxes are a hit and miss. They only replace the seals and they almost never replace the worn out wears.
Scottydoggs
NJ
came home from work, windows down i keep hearing this squeal sound, happens when i hit the brakes and after i let off for a bit. seems like a hung up caliper. ive not done jack to this truck other then oil changes in 3 years. so now work must happen. it was a good run i must say tho. tires need to be rotated, so alls not lost i suppose lol
and i just bought a battery powered impact gun and a new 3 ton floor jack, time to put that stuff to the test.
Which impact did you get? I have air, and it's a pita to hook everything up.
Scottydoggs
NJ
Scottydoggs
NJ
just checked my invoice and i paid more for it when i bought it. just a month or so ago. 79.00 for the gun, came to 95 with tax and shipping.
Teamiez
I tried the redheads, they were way to tight which I never thought could be possible but the ride was dangerously squirrelly, and had no return to center. Warrantied the box and the next one was damn near the same. Tried 2 gm oem reman’s and both had excessive play in 4,000 miles give or take. Ended up with a used oem from LKQ for $80 shipped with 91,000 on it and was the most tolerable
video of my steering box play with the gm reman...replaced by a Chevy dealer so I would be able to warranty them as much as possible knowing how they sucked and didn’t wanna do the labor a bunch of times
These are the exact complaints I've heard about aftermarket and remanufactured boxes.
Scottydoggs
NJ
Do you think it could do all 4 tires on 1 charge? Sux they only give you 1 battery.
we gonna find out tomorrow. plan to rotate the tires and take a look at my brakes. the better, aka more expensive brands seem to last a long ass time, so lets hope this one has the same longevity.
blueinkd
I went with a Reman unit from AZ... The supplier is BBB industries and they arent in the business of supplying junk to all the parts houses. Everyone touting those redhead steering gears and the blue tops, but I found as much negative reviews on their products. My unit been on since Early this year and I havent had a single issue, leak, noise or squeal. That mofo was heavy as heck installing it with one hand while hand starting the bolts with the other.
Need to do oil changes this fall in the Hoe and the Fusion, but I'm not seeing Shell Rotella Gas Truck oil anywhere in local stores. Last time I got it at WalMart but I'm not finding it there, not even an empty bin. Anyone seeing it locally? I'll probably have to order it online.
Hodmjstone
