Just Fishing
Can't fix stupid
Utah
For the O2 sensors, I'll just run them and see what happens.
Denso's have been good for me in GM vehicles in the past.
Soon i'll have a wideband sensor to compare off of anyways.
gunninks
Added a Tuffy Lock Box to the center console u=in my 07 Denali
FrankU
Babylon New York
Why did you suggest changing out the driveshaft? Are you referring to the one that’s heavier duty or did you mean going aluminum for the weight?
Those driveshafts are not meant to go triple digits. You'll need a larger diameter heavy duty balanced driveshaft. Many do get away with using the stock drive shaft's on triple digit runs.
Drive shafts do fatigue and twist , not a pretty sight. Cheap insurance really.
wsteele
Here is an interesting article on the subject.
kbuskill
NE. FL.
Just Fishing
Can't fix stupid
Utah
View attachment 345468View attachment 345469
What do you think of it so far?
I have been looking at getting something like this, mostly because i carry and having it bolted down feels a little more secure should i need to leave it in the car for a bit.
I'm also a lock nerd, usually things like this have a retarded/simple lock installed.
Retarded like a child with a paperclip, youtube, and a.d.d. meds could make short work of. :jester:
My current little cable lockboxes are stupid like this.
Good enough to prevent a smash and grab tho.
Just Fishing
Can't fix stupid
Utah
Anyone run a gauge pod/pillar thing?
Thinking about getting one for the wideband, that is should i just opt to buy the AEM vs pulling my innovate one from the vette.
I have the single pillar pod for an AEM wideband on my 02. I painted it to match the interior. Looks good.
St. Louis
I installed one of these cable type lock boxes using 2 of the bolts that hold the center console to the floor. I did have to drill new holes into the bottom of the lock box, and also used some washers as spacers underneath where the bolts go through because the factory console floor has recesses where the bolt heads are. I think I also used longer bolts.
Bill 1960
Testing the Limits
You probably watch Lockpicking Lawyer on YouTube then. That guy and Bosnian Bill have ruined me for ever trusting locks again. o_O
Just Fishing
Can't fix stupid
Utah
Oh yeah, and i have been having fun learning.
I have a bit of a knack for it, it's sorta relaxing.
I started pinning my own locks recently, chocked full of security pins and different weight springs. :jester:
Just my gate lock has some "alien technology" as Bill would say. :angels2:
I have a storage unit that has a German made lock that's worth more than the garbage inside of the unit. :patriot:
curbud
