Keeping coolant and transmission temps under control when towing in the summer heat
Foggy
KS
On the baffles, I made mine from scratch from black coroplast sheet, and used zip ties to hold them in place.
Where did you find this space aged material??? I looked on amazon, but there were so many
f'n choices !!!! 4 mil thick, etc ????
I'm going to update my baffles since you had good luck with it.. Mine are still there but not in the best of shape. so i figure I'll try this
Sparksalot
Bastrop County, Texas
It’s like gold. Hard to find.
Two sets because twins.
03_GMC
03_GMC
Also I thought I blew her up yesterday driving up to Genesee park to return the trailer. On the steepest part we got a flashing check engine light and started losing power quickly. I was able to make it to the side of the road and checked codes. Found cylinder 4 misfire and cleared it. I started it back up and it instantly gave me issues. I shut it down and checked codes again and same thing. I cleared them again and started it up and heard a ticking noise. I thought oh crap….. so I looked around and saw cylinder 4’s plug wire arcing to the header. ‍♂️ So I grabbed some zip ties and pulled it up and away from the header. Cleared the codes one last time and we continued on the road.
Geotrash
Geotrash
Dave
Richmond, VA
The master of the roadside repair! Nice work!
Tallpaulboise2
I have a 2011 Yukon Denali that had high trans temps when pulling my new trailer. Installed the TruCool and no more trans overheating. Now the engine temps are rising to 225 as soon as I get going down the highway. I thought the higher wattage fans were to be used for in town cooling. Mine are fine in town and cool right down when I get my speed down or get off the highway. What kind of restriction do I need in the radiator hose or should I just purchase a OEM item? I purchased this vehicle a few months ago, didn’t find a trans replacement on the Car Fax but it does have a 2020 sticker on it.
03_GMC
Ok so just so we have a better idea of what you have done.
Tru Cool trans cooler ☑️
Higher Wattage fans??? Need more info
tuned at all?
what do you mean radiator hose restriction??
Tallpaulboise2
tuned at all?
I am ready to purchase a tuner because of the increased towing I will be doing. Is the higher wattage fan to go on the drivets side? I noticed the passenger side fan hit high but not the drivets side. The restriction remark was a response to a thread I was reading.
03_GMC
So for a tuner you need to find a local tuner who uses HP Tuners and can change your cooling fan parameters.
I am not sure what exactly you mean by the higher wattage fan. Did you buy new fans or is one of your not working correctly?? Also I’m still not following the restriction question. Are you referring to the thermostat for the coolant or asking if you. We’d bigger hoses or a better water pump?
Geotrash
Geotrash
Dave
Richmond, VA
Thanks to @03_GMC for asking helpful clarifying questions.
What you're experiencing with the Tru-Cool and towing is exactly what I experienced as well. And by asking about the restrictor, I assume you mean that you're thinking if installing a Cold Case radiator and want to know what to put in that little hose that goes back to the coolant tank. Before worrying about replacing the radiator, here are the steps I would take if I were in your shoes right now:
1/ Open up the lower grill so that air can flow easily through it to reach the Tru-Cool when you move it there.
2/ Move the Tru-Cool to be mounted behind that lower grille.
Keep everything else, including your cooling fans the way they are for now, and go do some more towing. My bet is that you'll be just fine without having to take any further steps, unless you're in the desert (115ºF outside).
If you do decide you want to upgrade the radiator anyway, all you need is a small brass fitting that will fit snugly inside the hose and has a small hole in it (1/8" is enough) to allow a small amount of coolant and steam to pass through the hose back to the recovery tank, yet is too large to slip through the hose and into the recovery tank, because that would be bad. I found such a fitting on the Dorman parts tree at my local Autozone.
As for the cooling fan motors and settings, I didn't end up changing mine at all. So that's the final step I will take if I run into any more cooling issues. I already bought the 700W fan motor for the driver's side, and the fam blade to go with it, but haven't installed it yet. I also haven't changed my fan speed settings yet with a tune.
03_GMC
Anybody know the factory cfm of the cooling fans??
alpha_omega
Michigan
I’m finally getting around to installing a Tru-Cool on my 2011 Denali and will be doing a fair amount of towing with it (either horses or my 16’ enclosed trailer both are V-nose/wedge shape). Living in Michigan I don’t have the mountains or desert heat that some of you other guys deal with, but at the same time I don’t want to run into any of the issues you all have been fighting - regarding having too low of temps in exchange for too high of temps.
I guess my main question is, even for me living way out in “deer zone” (at risk of one of those rodents clipping the bumper and taking out my new TruCool) would you still recommend installing the new 40k down at the bumper grill vs the location that some others have used directly in front of the radiator, but with enough of a stand-off to prevent it from rubbing and allow a little better airflow?
I did install a B&M deep trans pan, wrapped the exhaust pipes near the transmission as well as wrapped the trans coolant lines in order to help keep as much excess heat away from them as possible. I still planning on running through the OEM radiator cooler and will be installing a cold weather bypass for the TruCool 40k. However, I just don’t want to sacrifice trans temps for engine coolant temps. Neither are a good idea.
i have been mulling over the idea of trying to space it more forward from the radiator or turning it sideways versus putting it down below but haven't even had a chance 2nd heatwave hit right behind the 1st, miserable outside right now unless I get up very early. not sure if moving it forward would cause more issue or less or even just angling it a bit lower. I need to get the grill off and experiment.
03_GMC
So with how mine is mounted it’s far enough back that slapping a rodent or two wouldn’t damage it. The one thing I haven’t done is wrap my long tubes and cross pipe. You can see I paid the price for that a few posts ago. I just love the way headers looked unwrapped but I may need to let that go. I know some guys were looking into mounting the Tru Cool sideways but I think upgrading to 3-4K cfm fans would be a huge help.
Phlipnstik
