cooki3mnster's build - The Black Pearl
cooki3mnster
cooki3mnster
Found their website, those look high quality! Which ones specifically were you looking at??
More than likely the Mini H1s. From what I can tell they are "almost" a direct swap for the Denali Projectors. I've been trying to find some decent Denali headlights but I don't mind waiting. The new headlights I installed are already plenty bright.
Also pulled the trigger on the front EBC pads and rotors, as well as an Airaid MIT. Going to wait until next check to pick up the rest of the pads and rotors and the Stainless brake hoses and parking brake shoes. I've noticed that the parking brake is either way out of adjustment or completely worn out. I've been kicking around the idea of attempting a brake fluid flush seeing as it has almost 200k on it and is 16 years old. Does any one have a good way of doing a flush without a Tech 2?
You need a set of adapter brackets and the mini H1’s will mount to the Denali style projectors. They also work in the Anzo u-bar ones if you’re inclined. I did mine a year or so ago.
adventurenali92
Big Bear Lake, ca
yeah what mark said^
I got the mini H1 8.0 projectors and the bracket from custom brackets & designs. Guy’s name is Nathaniel and sent me a complete kit. They go right into the OEM Denali headlights. I now have the anzo U bar headlights and put the morimoto projectors in them. And love them.
cooki3mnster
cooki3mnster
Those U-Bars look great on your truck!
Thanks for the lead on the brackets. I'm going to order some to have while I plan out what I want to do. I definitely plan on going with the Morimotos, just need to decide what housing to shove them in.
cooki3mnster
cooki3mnster
Dropped in the Airaid MIT (P/N 200-919) last night. Install was straightforward, I’m interested to see if the MPG will change over the course of the next few tanks. I do notice the exhaust tone is a little bit deeper under load.
Also picked up a set of NNBS style Yukon XL badges. I’m not quite sure how I feel about it. Might leave it for a week and see what I think. I really dig the shaved look, but I do like the added pop of contrast on the back hatch.
cooki3mnster
cooki3mnster
Also found a pic of my old Excursion, I've always had strong feelings for big lifted SUVS. This guy had a 6" Pro-Comp Lift, 20x10 Helo Maxx 8s, 37x12.50 Yokohama Geolanders. It was tuned, with 4' turbo back exhaust, and an intake. Regularly got 20mpg on the freeway. Honestly I really miss this truck, It was stolen in 2013, we recovered it a few weeks later but it was stripped and beat to ever loving shit. RIP Betsy wherever you are now.
Sparksalot
Bastrop County, Texas
Did you just replace the intake tube, or do more? I've been curious about this.
cooki3mnster
cooki3mnster
Just the tube, I had a full CAI on my old 355 and it was sooo loud under heavy load. All I wanted was something to smooth out the air flow and clean up the engine bay a bit. I’ll end up picking up an drop in dry filter soon. I want to stay away from the oil soaked filters so I don’t get MAF codes.
Sparksalot
I don’t think I’d care about loud because I’m thinking of thecopcar initially. I’m usually solo. I don’t want the oil soaked filter though, because I’m often in very dusty conditions.
cooki3mnster
cooki3mnster
If that’s the case check out Volant. I had one on my 355 with a ported throttle body and a tune. It. was. so. loud. It had 33s on it with 3.73s and when pulling hills it would search between 3/4 and let me tell you that 5 cylinders of fury would sing you the song of its people.
adventurenali92
Big Bear Lake, ca
I run a oiled cone style filter on a spectre cold air intake on my 2006 and the filter oil has never given me issues with the MAF sensor.
You won’t get codes unless you over oil the filter. I run one on my supercharged 6.0, it came with the Whipple kit.
cooki3mnster
cooki3mnster
Pulled the trigger on some retrofit parts! Ordered the Morimoto Mini H1s, 6000K Bulbs, and 35w ballasts, got the Mini H1 brackets from Custom Brackets and Designs, and picked up the Demon Eyes from Profile LED. I'm going to also order up some different reflectors for the headlights, I'm not sure if I want clear or lightly smoked yet.
Which headlights did you decide on?
cooki3mnster
cooki3mnster
Honestly, not sure yet. It might need to wait a bit before I order those. I kinda really like the U-Bar ones that you have one your truck. But I also like the simplicity of the stock style Denali lights. It might come down to a coin flip lol.
cooki3mnster
cooki3mnster
Yesterday I go some paint on the NNBS Calipers. Picked up some Duplicolor Silver Caliper paint, I prepped them with brake cleaner and acetone, taped them up and laid down 3 coats. I used the spray paint this time around as the brush on stuff I used on the Chevelle a few years ago did not turn out ver smooth or clean.
cooki3mnster
cooki3mnster
Gave the Pearl and wash and wax today, after all the yard work at my place and the new owners next door doing massive reno work the old girl was covered in dust and crap. Been trying out a foam cannon with CG Honeydew Snow foam wash, and the two bucket method. Followed up with some Mother Synthetic Carnuba wax. I’ve been trying out Chemical Guys products after reading @adventurenali92 build thread. So far pretty happy with the results, just wish Detail Garage was a little closer to home.
adventurenali92
Big Bear Lake, ca
Awesome foam bath! Love it! Glad to hear I can be a poster boy for chemical guys! Lol. Good thing you can order their stuff online!
Looking good. I’ve been using some of CG’s stuff for a couple years, it’s pretty good. I do use the Honeydew in a fiam sprayer that just connects to my hose. It’s simple and works great. If I have to pull my pressure washer out to wash my trucks it’s a disincentive and I don’t wash as often so I go this route.
cooki3mnster
cooki3mnster
I tried a foam sprayer that attached to my hose but got worse than awful results. I have an electric pressure washer that is super small and quiet so it works for me. It definitely takes longer doing it this way but the results are so much more worth it.
I picked up some nice rags from The Rag Company and replaced all my ancient microfibers and car wash towels. I have a few towels from them that are crazy absorbent and make drying this giant beast go by so much more quickly than before.
CrackerJack135
