Tech 2 Purchase
George B
¯\_(ツ)_/¯
Oconomowoc, Wisconsin 53066
It is your phrase "first connecting" that I was trying to pin down.
When you power up the Tech 2, there is no "connection" by which I mean that there has been zero communications between the Tech 2 and anything in the truck. If you select say Diagnostics, the select your year, vehicle type, powertrain, engine, transmission, Transfer case, Data Display (example), Engine Data Display,,,, up to this point there has been no communications attempted by the Tech 2 and the vehicle.
Only when you select, for example "Engine Data 1",, where the next screen normally flashes "waiting for data", only then are communications attempted.
Is this where you get the error(s).
Here is a little better explanation. Two scenarios with out the candi.
1. 2002 Envoy
Connect cable to truck and turn ignition to KOEO. Power up tech2. Gauges jump to full then zero in the cluster and DIC reads UNKNOWN DRIVER. I have to cycle the power button on the tech2 and reboot a couple times and when it doesn’t do the above shenanigans it works fine.
2. 2005 gmc canyon
Connect cable to truck and turn ignition to KOEO. Power up tech2. Don’t notice any weird shenanigans but in this case was trying to communicate with the PCM. Received a NO COMMUNICATION error. After rebooting the tech2 several times it works and I can do the operation I want to.
With the Candi on my 2013 suburban KOEO the tech2 fails to recognize the candi but after several power cycles and a wiggle of the connector at the candi it connects but it occasionally causes the truck to display weird service messages. I have reloaded the firmware and tried a new main cable.
George B
¯\_(ツ)_/¯
Well, I don’t know what to do. I was hoping I had a unique VCI and everyone else had a QC mark. :mad:
I hate to buy another VCI to find out it’s not the issue. I wish it would fail a self test so I could pinpoint the issue. Even the Candi tests ok once it is detected.
St. Louis
Do you run the tests that are in the submenu and also require the loopback plugged into the side jack?
St. Louis
At first they would not respond. Don’t know what I did to change that.
I’m ready to throw this ******* thing in a trash compactor. Damn thing will not read candi no matter what. It did at first.
Send it to George B, maybe between the two he can get one to work correctly
How long have you had it? I assume you’ve seated the connectors firmly a few times?
oldtimer
Santa Clara County, CA
I received my Tech2 from chinacardiags a couple a weeks ago. I noticed the DLC cable connector would not completely seat into the VCI connector. The cable connector has a molded boss that locks the VCI latching lever. I had to trim the boss on cable connector to clear the VCI latch.
Silver marker highlights trimmed corner on boss.
Partially seated.
Fully seated.
George B
¯\_(ツ)_/¯
Good idea. I would intercept it hitting the trash if shipping was reasonable. Sounds like it’s kind of jacked up tho.
@Sparksalot shoot me a pm if you are seriously considering tossing it. Maybe we can work out an agreement and end up with a fully functional unit. Between the two of us.
smokymtn65
East TN
I might throw mine in too! LOL
MonteJ
