2013 Tahoe (5.3) gave a red oil light and was warning of low oil pressure. At the time pressure on dash was just under 20, maybe 18. My first thought was sending unit because oil level was good , but oil needed changing too ....very black. I changed the oil and filter and towed it to the shop next day. They dismissed the sending unit and thought it may be pickup tube O ring. They checked that by overfilling engine and lifting it but there was no indication it was the O-ring . They then were thinking cam bearings, so I drove it home after starting with pressure at 33-35 and when it got to running temp the pressure was at around 23. My daughter has been driving it several days with no warnings....I'm assuming the oil change helped . My question : At running temp., With the truck's pressure (at idle) at around 23 or so , is that somewhat normal or is it too low?
