Squeak when starting
G-Frog
Nova Scotia
My 2021 Yukon SLT has developed a squeak when it starts.
Anyone ever heard of anything like this? Engine mounts maybe?
There is also a similar squeak when releasing the brake after slowing down quickly or when the body leans in a sharp curve at city speeds 50 km/hr (30 mph) or less.
pop the hood and record in the engine area while the vehicle is started or use remote start and see if you can pinpoint it better. might take a few tries to narrow it down
Holy Roller
Starter slightly out of alignment. Easily resolved by dealer.
G-Frog
G-Frog
Nova Scotia
The Yukon was at the dealer today and they sent this video explaining the problem.
https://steeleauto.com/video/2/alzygrla
It is suspected that as you brake and your foot is off the accelerator, the cylinder de-activation occurs and as you take your foot off the brake pedal, cylinder re-activation occurs causing added exhaust gases and making the valve move. Same issue in curves, foot off the gas as you the approach the curve and as you re-apply gas in the curves, the cylinders re-activate.
I had a similar noisy exhaust butterfly valve changed last year on my 2018 Traverse.
Corrosion happens quickly in the northern hemisphere.
GMT800 2005 Tahoe Z71
Navy Supporting Member
WOW! 5-7 days wait for part and bet there is a recall sent out. Looks like a lot of crud under there for a 2021.
G-Frog
G-Frog
Nova Scotia
It's called undercoating; also known as rustproofing. You can hear the tech talking about it. Looks worst than it is. The stuff that is applied on my Yukon (Formula 3000) is a clear semi-gel like substance.
It was tested by the US Army and Canadian Military some time ago. You can test reports here: https://corrosionfree.com/wp-conten...t-of-Defence-Report-Highlighted-Text-copy.pdf
In these Northern neck of the woods, they use a lot of salt on the roads during winter. If you don't undercoat/rustproof, you'll get rust before the end of your first winter.
35+ years of working in the auto repair field and 10 as a tech and 25+ as a service manager. I can tell you stories about dealing with rust caused by salt. I saw rust all over the tab that was holding the spare up and as he moved around under there, he was fast enough that could not get a good clear sight on everything. One of the reasons I moved to the PNW.
Vinnoto1
8K Miles on my YUKON XL and it is squealing for 30-60 seconds whenever it starts.. Based on the above something regarding the belt is failing, has anyone been to dealer regarding this?
BigJim419
Did you get it serviced under warranty... My 21 is now making the same noise. Identical to sound yours was making!
Dh1280
