Engine Oil Pan Gasket Change 6.2 Yukon L92
donjetman
Got the oil pan off today. The stabilizer bar was already off. It was removed as part of the rear main engine seal job that I'm doing too. Remove the cross member (4 bolts) that's under the pan. The 4 steering rack bolts need to be removed. Both axle shaft bolts(6 ea) need to be removed. The 4 bolts that hold the front differential to the frame need to be removed too. Then lower the differential until it rests on the driver side lower a-arm attach point. Let the passenger side drop until the pan can be removed. It doesn't need to come all the way out. This will ease re-assembly.
Here are a couple of good videos:
View media item 27422View media item 27423View media item 27421View media item 27427View media item 27425
donjetman
donjetman
I got the oil pan cleaned up and painted and ready to reinstall. Installed a new oil cooler adapter gasket Felpro#72462, a new oil pump pickup tube o-ring Felpro# 72401, a oil pressure relief valve deflector GM# 24237531, oil pan gasket GM# 12612350.
View media item 27429View media item 27428
donjetman
donjetman
While in the pan to change the gasket #12612350, I installed an AFM Oil Deflector, GM# 12639759, to the AFM pressure relief valve, per TSB 10-06-01-008M. I also installed a new oil pickup tube o-ring, Felpro#72401. The old o-ring was hard and brittle. I installed the pan back on the engine today.
TSB 10-06-01-008M link:
https://f01.justanswer.com/ebrock63...il+Consumption,+MIL+ON,+Engine+Runs+Rough.pdf
View media item 27426View media item 27431View media item 27434View media item 27430View media item 27435View media item 27436
Jason in DLH
Cheeseburger and Fries
MN
Good write up! I’m looking into this as my pan is currently leaking. I would have never thought about painting it and replacing all those other items as well. Glad I saw this!
donjetman
donjetman
She's got 163k miles now. It's been 2 yrs and 30+k miles since I did all that work and she is still dry as a bone and doesn't consume or leak any oil. I left the catch can on but it doesn't catch much of anything with the new improved valve cover and the piston rings freed up.
1BADI5
DMV
Nothing better then installing new or clean parts!
Tiki
What was the part number on the new valve cover gasket? I’m trying to figure out if my L9H has them or not.
donjetman
donjetman
2007-2008 Valve cover driverside – GM# 12570427
2009-2011 valve cover driverside - GM# 12642655
Replaced the whole valve cover, not just the valve cover "gasket". The vc gets replaced because the improved pvc system is built into it. The original cover and its built-in pcv system was/is inadequate.
Read GM TSB: https://f01.justanswer.com/ebrock63...il+Consumption,+MIL+ON,+Engine+Runs+Rough.pdf
jkhuntzinger
