Metal chunks in oil pan..
McLeod Crouch
Yeah so found these in the oil pan.. any ideas? truck was running fine. The brownish parts are plastic it feels like. The others are metal i believe.
fire730
Louisiana
Plastic is probably the timing chain tensioner. Metal maybe from the VVt actuator or from the tensioner too.
Best guess although I’ve never seen this happen on an LS.
Running bad or any CEL? Did you remove the pan already?
Looks like you need to pull the front timing cover.
Sorry I see that you answered some of this in the first post. But I still think you are pulling the timing cover.
McLeod Crouch
McLeod Crouch
No it was running fine no lights. Ive never pulled the pan before, i just bought it about 5000 miles ago.
Now that you guys mentioned it, that does look like timing chain tensioner pieces.
BG1988
I kinda wonder if there was an issue with the timing chain and they fixed that, but never pulled the oil pan to clean it. Would be interesting to see what the timing chain and tensioner look like.
easy to check see if any of the bolts have been pulled or have some wear on them..
Buy a AFM disabler if possible...
The mpg will be the same.
wsteele
Sounds right to me.
Geotrash
Dave
Richmond, VA
Timing chain tensioner for sure. Time to pull the pan and timing cover and replace.
Barry Vaughn
I've never been inside an ls but being a major sb chevy rebuilder, the big piece looks an awful lot like a rod bearing. If it is, I can't believe it's still running without a LOT of noise. For those ls experts, what does it look like to you?
Timing chain tensioner. If it was a rod bearing the engine would have self destructed by now.
thompsoj22
Im in complete agreement with this post, pull a valve cover and rotate the crank pulley for/aft and look for excessive play watching valvetrain/lifter movement. If your cam chain is running without the tensioner/guide it would be noisy/sloppy/maybe even slapping on the cover?
Nah, there's not enough slack for it to visibly affect the timing. It also can't slap anything. It can whip around on deceleration, but not much with an automatic trans unless it's in manual mode or held in a lower gear. The LS3 just has a block (damper) that doesn't actively retain the slack in the chain like this tensioner does. Same size timing chain.
brice715
