Finished the Dad Wagon but fighting with exhaust
Racie
Almost done with all my tuning etc on my Escalade after I bought it from previous owner. Problem is I have the Kooks long tubes and Y-pipe. I have a slight exhaust leak or header tick that’s driving me nuts. I’ve even smoked the system for an hour and found no leaks, still replaced flange gaskets and not it seems to be coming from the header collector area. Also I’m thinking of going to the large 22” Magnaflow because the blowmaster is way to vicious and obnoxious sounding. I’m not 18 anymore lol.... anybody running the large magnaflow with longtubes?
Catted Y-pipe? I gave up my cats when I got headers and it took 40" of muffler to get the exhaust back to a reasonable level. It's actually quite nice again- very mild hum when cruising but roars when you mash it. I have 18" and 22" Magnaflow knock-offs, made by AP Exhaust, from their Xlerator line.
Racie
Racie
Yea it’s a catted kooks setup...cammed, stage III heads, ported 2.9 Whipple and 102mm TB with 1 7/8” longtubes. I put a 70 series FM on it and it still sucks ass and I’m not liking it at all. Not for daily business anyway....and I feel like it’s choking it.
CMoore711
Just so I'm understanding the exhaust right; 1-7/8" Kooks LT's to Kooks catted Y pipe to stock exhaust system with a FM 70 series muffler welded in where the stock muffler was?
Do you still have the exhaust flap?
Do you still have the OEM resonator in the back over the rear axle before the tip in the exhaust system?
On another note...
Sounds like a sweet build.
What kind of power did you put down with that combo? WHP/WTQ?
Standard Whipple Pulley or did you pulley down?
Are you still running the stock transmission and converter?
Racie
Racie
On another note...
Correct and Exhaust flap is gone....OEM resonator is still in place. Transmission is tuned and running a small converter and cooler. Running a tad over 10lbs of boost putting down 750 on a mustang Dyno. Honestly I could care less at this point to loose a few HP to have it quieter. It’s hella fun to drive and the shock on people’s faces is priceless. But I have other big HP toys so this one doesn’t have to be so extreme for daily duty I’m sure it will still be fun with a little less I just don’t want it feeling like it’s choking to death.
CMoore711
Nice set-up. I bet that is fun. If you've smoked the system with no leaks there probably aren't any. If it's a header tick you're hearing that kind of stuff comes with the territory of running headers. Sometimes that stuff is hit or miss if it's an issue or not. Only thing I think you could try is ceramic coating them or wrapping them in hopes that it provides additional sound deadening from the headers? I guess there is an offset chance there's a porous weld or small weld bit of steel bouncing around or causing a noise, but those type of QC issues are slim with Kooks from my experience.
I'm a bit surprised it's still loud and obnoxious with the OEM resonator still place. I don't have headers or anything; But I got my hands on a Corsa 3.5" in/out muffler from their #14866 kit for the 6.2 Silverado/Sierra's and had that welded in, flapper removed, left OEM resonator in place and the sound/tone level is perfect. Not too obnoxious on cold start, but you know somethings there, great sound at WOT, and zero drone ever.
I think the Corsa Sport exhaust kits by themselves installed on the Tahoe/Yukon/Escalade are almost too loud on the cold start and at WOT. I never wanted to go that route anyway because their kit for the K2XX SUV's is still 3" and the OEM piping is 3.5" on the 6.2L L86 models.
Always got my eye out for a lightly used Corsa #14866 kit for 6.2 Silverado/Sierra's due to it still being a 3.5" system. I'm confident it would take minimal modifications from a muffler shop to fit our K2XX SUV's easily and add a 3.5" Vibrant resonator in the back around where the OEM one is located and it'd be perfect sound/tone, wouldn't sacrifice performance with the mandrel bent 3.5" system, and it'd all be stainless.
Racie
Racie
Yea I’m going to be wrapping the headers next when I take the flowmaster off and I’ll probably do the Y-pipe also. Never had an issue with Kooks or American racing but I had the Kooks on the bench and we actually welded all the way around the flanges where the primaries connect. I’m going to re-inspect the collector area also and yes I did an hour or more smoke test and found nada . Thinking I can get lucky and find a corsa set up or do a magnaflow and vibrant resonators and hopefully that’ll get me where I wanna be.
RThomasII
I ran the Magnaflow 12909 with the same headers/catted y pipe on my 2019 Denali (rest of the exhaust was stock) and it didn't really sound too much different than stock.
I've got the full Magnaflow Catback exhaust (no other mods) on my Escalade now and its got a nice mellow tone to it. Cold start is a little loud but overall it gives the truck a nice growl without sounding like a muscle car. Sounds about right for a luxury SUV imho.
That said... I'm getting rid of the catback and going with a custom built exhaust.
Ugh- Blowmaster. With all of that you need a straight-through style muffler(s).
STORMIN08
No matter what your choice is to be...even a 30 dollar turbo muffler [s shaped internal) will flow better than a FM...and that is proven fact with documented footage to boot.
Even engine masters tested this not long ago...
Racie
Racie
Picked up a 22” Magnaflow and Vibrant resonators yesterday! Hope to see a big change Monday.
Slow5.0
Missouri
Off topic, Racie, do you have 4wd or 2wd esky, im asking this since im looking for LT headers and catted Y pipe. There is a lot of LTs out there but they saying there my be clearance issues with LTs or Y pipe on 6.2 4WD trucks/suvs. If yours is 4WD how is clearance ?
Also are those fake cats that kooks makes or they is stuff inside, or are thry those green ones ?
Thanks
Racie
Racie
Btw last week i came across Denali for sale at local dealship. It is 2016 With whipple and FM. I test drove since its got same mods im thinking to do, wilwiods and 2-4 drop. When i hear exhaust it remind me of my 94 Stang GT vert with FM
Revs
https://youtube.com/shorts/zBaiE9ieiQk?feature=share
Idle
Yea Slow5.0 mine is actually louder and deeper than that right now...I couldn't post a vid the other day but I will try again here shortly. To answer you question above I'm not sure on the cats from kooks but I do have the Y-pipe and cats from them. Also my Esky is 4wd and I have plenty of clearance.
91RS
GA
Get a Corsa Touring if you don’t want it super loud. It’s very reasonable in my 08 with headers. It is also perfectly normal to hear more valvetrain noise with headers.
MWR Denali
I've got a Corsa Sport on mine with Kooks longtubes and cats. It's downright ridiculous on a cold start and at idle, but remarkably quiet on the highway. The system has been on there since ’07, so the muffler is beyond “broken in.” When I finally replace it I may find a factory 3.5” system or perhaps modify the 3.5” magnaflow system for the Escalade/Denali. I am really surprised there are so few 3.5" systems for these trucks.
Slow5.0
Missouri
This 16 Denali that was for sale only have flowmaster muffler without resonator,. Factory exhaust manifold and factory cats. It wasnt that loud. Sound just remind me on my 94 Mustang 5.0 with FM catback
Slow5.0
Missouri
You didnt say are yours kooks cats real or are they looks like cats but nothing inside ?
Thanks
Drewphil
