Help me prepare for my motor swap.
tRidiot
tRidiot
Yes I see that list, it's hard to find some of the genuine parts on Amazon, tons of Chineseum on there, though.
S33k3r
Dallas, Texas
One thing that I always used to do while I worked in the HVAC field working on huge centrifugal chillers was to put all your screws, nuts, bolts, etc, into separate zip lock bags as you take them off, and LABLE THEM as to exactly what they are so that you can reassemble it a LOT easier. LABLE them as YOU think the part is, to make it easier on you. Same goes for hoses, and other parts as well, just use larger bags. Good luck !!!
One other thing you can do, if you are willing to label your bags, is take a bunch of pictures, and include the associated picture reference on your bag.
fasteddy
I think its all chineseum.....
If you're an auto parts company and not mfg in china or mex you're soon to be out of business.
I think its all the same, just branded differently. You're paying for ACDelco branding, not quality.
Watch....
I'll go dorman, you go ACDelco and we'll see if my parts fail sooner.
I go 170mph with dorman sensors. I haven't had one fail yet.
The motor mounts are a different story. I think the rubber is just different
GMT800 2005 Tahoe Z71
Navy Supporting Member
Your Dorman oil sender with screen is Filter GM# 12585328 and sensor is 12677836
Dorman #917-754-crank sensor is 12560228
Dorman #926-084-knock sensor is 2133521
Dorman #917-715-cam sensor is 12561211 or 8125612110 or Delphi is SS11368
tRidiot
tRidiot
So I found a difference, I guess - the water pump on the 5.3L and the 6.0L are different. Not surprisingly, I guess, but I almost ordered the wrong one.
tRidiot
tRidiot
This shows up as compatible with my 5.3L, but to check against the 6.0L I try the Suburban 6.0 or Silverado 2500 HD and it shows as incompatible.
Then it needs to be looked up by application because I took the supplied Dorman number and crossed it.
fasteddy
I'll try mine first. I've done it before. Mine is only 2 months old.
Bolt pattern is the same. Just trying to avoid another $100....LOL.
$100 here
$100 there.....
$150 for the AC Delco AC compressor......
$100 here
$100 there.....
Stand by, your nickel and dime spending, $100 and $150, is just starting. You want to surprise yourself? Keep a list of EVERY CENT spent that you had not allowed for in the beginning. If there is a woman's opinion involved in that dollar figuring, keep your head covered and get ready to duck.
tRidiot
tRidiot
I assume it could be a capacity/flow issue. For the 6.0 maybe it has higher flow rates, I dunno. Kind of like the A/C compressor the 10S17F for w/o Rear A/C and the 10S20F for vehicles WITH Rear A/C - extra capacity for extra cooling. I think if I do it, I'll go with Denso which will be cheaper than AC Delco, but is the OE supplier anyways.
tRidiot
tRidiot
yeah, I'm experiencing that right now - my shopping cart on RockAuto at the moment is at $650 shipped, not including A/C supplies, window regulators a rear blend door actuator or the Tech 2 tool I am wanting.
The wife is getting used to just sighing and shaking her head. Making her think we should have just gone to the dealer and gotten something else. <sigh>
That RA cart ain't shit! I just got delivered this week and last week over $2000 of parts that I bought at RA. I have the invoices and can prove it. I am literally throwing money at my rig. It's FUN!
tRidiot
tRidiot
Well, I'll end up over 1200, maybe more by the time I get the stuff I want to do - and with the motor, labor, trans, parts, etc, I'm gonna probably be up over 7 large.
I don't even want to whisper that within earshot of my wife...
Jimmyy
Minnesota
“There are 3 prices you pay for stuff, 1 the price you paid . 2 the price you tell her you paid. And 3 the price you pay when she finds out the real price you paid”. GL
tRidiot
tRidiot
No Vehicle Specified
STANDARD MOTOR PRODUCTS C09001 Oil Pressure Filter $ 3.09 1 $ 3.09
2004 CHEVROLET SUBURBAN 2500 6.0L V8
ACDELCO 12677836 Oil Pressure Sensor $ 34.79 1 $ 34.79
ACDELCO 2133521 (213-3521) Knock / Detonation Sensor $ 42.79 2 $ 85.58
ACDELCO 12703898 Water Pump $ 139.79 1 $ 139.79
ACDELCO 2134514 (213-4514) Temperature Sender / Sensor $ 13.64 1 $ 13.64
ACDELCO 38158 Belt Tensioner $ 27.99 1 $ 27.99
DELPHI SS10206 Crankshaft Position Sensor $ 45.79 1 $ 45.79
DELPHI SS11368 Camshaft Position Sensor $ 25.79 1 $ 25.79
DORMAN 917033 (917-033) Knock / Detonation Sensor Connector $ 13.86 1 $ 13.86
FEL-PRO MS92465 Intake Manifold Gasket $ 16.02 1 $ 16.02 (valley pan)
FEL-PRO MS96587 Intake Manifold Gasket $ 41.79 1 $ 41.79
FEL-PRO MS92467 Exhaust Manifold Gasket $ 8.69 1 $ 8.69
GM GENUINE 12567915 PCV (Positive Crankcase Ventilation) Valve $ 4.46 1 $ 4.46
GM GENUINE 25828247 Motor Mount $ 77.79 2 $ 155.58
Shipping Ground $ 39.96
Tax $ 27.75
Order Total $ 684.57
Here is what I've got so far...
fasteddy
Thats funny......how true!
fasteddy
I'm probably gonna be around that too......for engine/trans complete.
The L86/10L90 swap would've cost me close to 10K w/o a cluster.
Then I would've spent 3-4 months trying to figure out how to get a fuel gauge to work.
But now with the new baby Duramax I'm thinking I'd rather have that. Its almost as fast as the 6.2.
And that "almost as fast" is making me think they did that on purpose.
I wonder how much those will be from the wrecked T/Y/S. The trans is the same.
Some folks are seeing 30-32 hwy MPG from that little 3.0L.
hagar
If it's coming as a long block with flywheel, be careful of what flywheel/flywheel spacer it has. Unless it is out of a vortec max or sikverado ss, it will originally have a 4l80e trans, and there are flywheel spacing differences with the 4l80e vs the 4l60e you have. Unless you have a 6 speed auto, I didn't notice what year truck you have.
tRidiot
tRidiot
Mine is a 4L60e, a 2004 Tahoe 5.3L. So what do I do? How do I check this and what do I do about it? It's been delivered and it is at my friend's house who is doing the swap. He is about 20 miles away and I can't get up there until tomorrow evening, probably, but I am headed that way then to take some parts... what do I look at, what do I measure, etc.,?
Or should I just email the builder and ask him? I will do that anyway, and see what he says.
Good point, and thanks for the tip.
a1parrothead
