Just in case anyone is interested, the torsional stiffness varies by the fourth power of the diameter. Put another way, if you keep everything else the same (bar length, material, etc.), and just vary the diameter of the bar, doubling the torsional stiffness of the bar requires only a 19% increase in the diameter.
Because the outside diameter has such a large influence on stiffness, a hollow bar doesn't lose as much stiffness as you'd think, because the material toward the center doesn't contribute very much. Using the example above, if a 1.19" bar is twice as stiff as a 1" bar, a hollow bar with 1.19"OD and 1"ID is just as stiff as a solid 1"OD bar, but only weighs 42% as much (if I did the math right).
Preach. It's the same effect as an I-beam, but rolled into a cylinder. For an I-beam, the strength to resist bending over a long span comes primarily from the height (depth?) of the vertical wall between the two narrower horizontal top and bottom pieces. It's not from the thickness of that vertical wall.
the_tool_man
Upstate South Carolina
Exactly. An I-beam is optimized to concentrate as much material as far apart as possible to minimize weight and provide lots of stiffness against bending.
Sparksalot
Bastrop County, Texas
Yeah, this truck was in TX and has over 10k hours engine run time. I think it spent a lot of days idling in the desert with the AC on and the under hood temperatures roasting.
I've been thinking about some kind of hood louvers to put on thecopcar to help with heat soak when I'm moving slowly off the beaten path.
Just Fishing
Can't fix stupid
Utah
Can anyone recommend a brand of split loom they know to be durable for under hood use? The OEM wire harness loom around the engine is in terrible shape from becoming brittle and a lot of it is completely gone.
On previous projects I’ve used whatever was handy but given the poor performance of what GM used it’s got me thinking about the (lack of) durability of Chinese plastics.
I don’t mind the price for quality stuff. Rather do it once and do it right.
Thanks in advance for any recommendations.
For non split loom, i have been using heatshield products and DEI.
DEI also has some great Velcro heat shielded wire looms.
For split loom, i got a big spool from amazon when i did my boat and yup, you sure get what you pay for!
For the most part, i was just running primaries and lights through the cabin and not anything that would get direct sun or exposed to heat from the engine, so i was fine with it.
Mostly i just used a quality electrical tape to wrap the loom for extra protection (3M).
It was all very heavily shielded marine grade stuff anyways, the plastic loom was just an extra level of protection.
Buy some name brand stuff, better if you can find some with good reviews.
Convoluted Tubing, Wire Looms, and Wire Sleeves | Summit Racing
most of what summit carries should be gtg for the most part.
And reminds me, i need to order some of this crap.
I have a few little sections under the hood i would like to clean up while everything is apart...
:cheers:
Charlie207
LFOD, New Hampshire
An electric aux. fan will probably be a much better option if your "off the beaten path" requires you to drive slow.
The passive louvers aren't going to allow for much airflow at low speeds.
Sparksalot
I'm not after additional airflow per se. I've got the big fans on the radiator already. I'm thinking about the heat captured under the hood, and allowing for convection to happen.
aflumb
Las Vegas
Well after 2 year I finally got the stuff to finish installing DL3 style mirrors on the Tahoe
The new 1aauto mirrors
When I started this project I found a set of DL3 mirrors and the switches. Total cost $50’ish buck. But the passenger side arm was broke and later found out the motor was broke
So after trying to walk past both vehicles in the garage I was done with avoiding mirrors
(My 17 Mega cab has power folding mirrors)
To get all to work I had to use my factory switch bezels. Passenger side was a direct swap. Drivers side I hade to modify it for the 09 switch to fit
A lot happier now. Now to wait on the sub setup to get in.
1BADI5
DMV
Got some center caps for the declass.......not a perfect fit as I expected.......I have a trick up my sleeve though.
I also have a set of black caps on the way too. I only got chrome to keep the PPV look
Lower ball joints are being a pain to remove. Hammer didn't work. Heat didn't work. Pickle Forks didn't work. Now using a ball joint separator from Harbor Freight. Worked fine on a stuck upper ball joint but we have been grinding away on the tool to make it fit the lower ball joint and ran out of time. The girls are busy with their social schedules you know!
So at this point the struts and half shafts are out, calipers hanging on S-hooks and the engine oil cooler lines are disconnected but not removed. The front differential has been lowered but I think we're doing to pull it tomorrow to make more room. The front bumper cover and lights are off, we found the leak that the dealer said was not there, the lower connection on the condenser is leaking green oil everywhere. Bought an AC O-Ring and Seal kit from O'Reilly and had them refund me the condenser I ordered.
Bought a canopy from Harbor Freight and have that over the hood area in case it rains, all exposed connectors are pointed down too. Canopy secured on three corners with old brake rotors.
I forget to check and did not know that the lower control arm bolts and nuts are 15/16ths. 23mm too small, 24mm a little loose. Hopefully they'll come off tomorrow.
Still haven't gotten to the motor mounts or transmission oil cooler lines. Sure wish I was in my twenties again, all of this stuff would have been done already! The Good Lord is giving me patience but I keep wanting more.
Bill 1960
Testing the Limits
As soon as I’m done with crawling underneath this thing on a regular basis, I’ll be hosing down the underside with sheep dip (Fluid Film). I don’t want corrosion to get a foothold. I’ve been a long time user of FF with great results. However that doesn’t stop me from assessing other products. Last year I tried out some WoolWax, which is close to FF but goes on thicker. This project I’m going to try a Cosmoline product in some of the areas exposed to spray from the tires and see how it holds up. Literature indicates it will harden to a waxy consistency. FF never hardens and does get washed away from areas exposed to a lot of spray.
BadDaddy2003
