Rocker panel options..
JMEngland88
Hey guys. So, as pretty much everyone who owns one of these, my rocker panels have rust. What options are available to remedy this? Now that the years have gone by and these trucks can be had for a few grand, the thought of paying thousands of dollars to have new metal ones welded in and repainted and everything is hard to swallow. What have you guys done to at least make it look better? I've tried searching and can't find any pre-made solutions for us SUV guys, other than modifying the bushwackers made for the pickups.
Glad to be back btw
Speedslow
I welded them on. But I’m a body man. I would suggest to just do it the right way the first time. If you shop around sometimes you can find a body man that will do it on the side for a good deal. I know shop prices seam high but it is a decently big job. Try to find someone who will do it for a flat rate rather than paying hourly from a shop but make sure they know what they are doing.
FirstTimerTahoe
Glad to be back btw
I'm right there with you. I've seen several metal options for upper and lower rocker panels. Most of them need welded in. Some slip cover options, but they are elusive to find again. From what I understand we have to order Silverado options and trim them to fit? I could be wrong, I'm searching for this solution myself to be honest.
OneofFew
Talullah Falls, Ga
I had found plastic rocker panel covers on Ebay. I did fix the holes in the rear wheel wells where water was getting in and cut out the rust and sprayed rust inhibitor. IDK if those rocker panel covers are still available, but they did fine for me.
CrackerJack135
