St. Louis
I received the replacement motor mounts from RockAuto on Friday, but I spent the weekend installing a 24k btu mini split in my garage. Probably won't get to the mounts until this weekend.
Now I can do it in a cooled garage!
I had to install a new 30a breaker and about 60' of 10ga wire and mount a disconnect on the outside. That took most of Saturday afternoon.
I already have a ceiling mounted propane heater, but the mini split has a heat pump and will be more efficient unless it gets really cold outside, then the propane heater will be a backup.
the_tool_man
Upstate South Carolina
Did your parts come in? Also does anyone know if these lower or raise the motor at all from the factory spot? I’ve got some clearance issues on the Speed Engineering long tubes.
The H3 mounts don't relocate the engine at all. They take up less space. But that's due to the much smaller heat shield on the mount, not because the mount is shorter.
Geoffsfas10
St. Louis
i want to know how the motor mounts go since i have to do mine soon as well
Bill 1960
Testing the Limits
Looking good, wish I had a white one.
Long travel front end?
No, it’s a ProComp lift with at present the Monroe struts that were on it when I bought it. Later I’ll probably switch in some Fox coilovers when the supply chains sort themselves out again.
I don’t foresee long travel in my future as that would get wider and it’s already wider than I like.
Bigkevschopshop
Northside H-Town
Let me know how the Mini split works out for you, I have a 18k BTU window unit in the garage and have been looking at replacements that are a bit more efficient.
the_tool_man
I can say with confidence that a mini-split is FAR superior to a window unit. You get significantly better efficiency, better control over air handling and temperature, and programmability that a window unit can't come close to.
Installation is pretty easy. The outside part sits on a slab, or a bracket on the wall. The inside part hangs on the wall on a bracket, similar to a microwave oven. You need a 3" diameter hole for the line set to pass through, and a single circuit to power the whole thing.
I've had a 3/4t mini-split in my bonus room for 12 years with zero issues. I spent uncle Joe's stimulus check on a 1t unit for my workshop. It's on a pallet in my garage waiting for a free/non-rainy weekend to install it. This will replace a very old, loud and inefficient window unit that I can't wait to get rid of!
Don't wait. Do it.
Just Fishing
Can't fix stupid
Utah
A little payback today for all the time and money invested.
Making me want that lift...
it would fix that ground clearance issue i have with the hoe
This 6" one was too short to bother with the mesh, so it's all heat shrink:
img_5801-jpg.277625
It runs from the engine block (at the bolt for the power steering pump bracket) to the frame (under an engine mount bolt):
img_5802-jpg.277626
Copied the factory alternator-to-main fuse cable:
img_5805-jpg.277627
With very minor trimming of the mount on the firewall, the lug fit fine:
img_5807-jpg.277628
Followed the original routing and was even able to slip the terminal boot on after a little squirt of B'laster:
img_5808-jpg.277629
I want to replace the battery terminals with some marine post-to-stud adapters. I'll make the positive lead from the battery to the main fuse when I get those terminals. I'd like to make a starter wire as well.
Giving me ideas, as I try and find things to keep my self entertained while the machine shop takes it's sweet sweet time...
Too late, but i love this stuff for wrapping wires. Amazon.com: Heatshield Products (204011) 3/8" ID x 10' Hot Rod Sleeve Roll: Automotive
Lots of different sizes, and it looks great with a little shrink tubing to seal the ends.
In the old vette, the dashboard is a big piece of Styrofoam, I found a few somewhat unfused wires that go within inches of that piece of foam.
few years back; I had the dashboard headlight switch go out, started a mini fire.
Once i pulled the dash in order to fix it i saw how bad it could have been.
One inch away from that big piece of white Styrofoam!
then the problem that fiberglass is technically flammable. :banghead:
:jester:
Yup. every wire i could get to, got wrapped with that heatshield stuff.
:waytogo:
And, maybe tomorrow I'll harass the machine shop again...
if they don't think they will have it done by this weekend, I'm thinking about ordering this: Total Seal Piston Rings 8910 Total Seal Piston Ring Squaring Tools | Summit Racing
:jester:
:waytogo:
Thanks for that one but this time I AM only adding it to my list, not ordering it by mistake.
MonteJ
