tahoe no oil pressure
tneels
I have a2013 chevy tahoe 5.3 blew the engine. purchased a used engine or it in stayed it up and no oil pressure on the guage.I dint want to blow this engine up what do I do??
wjburken
Eastern Iowa
First off, you posted in the 2021+ section instead of the 2007-2014 section. Will need to see if a mod can get this moved.
(@07Burb @soulsea @NathanJax)
No offense, but your post isn’t the clearest. I’m guessing you said you blew a motor, replaced the motor and now the new motor is showing no oil pressure.
Who installed the motor?
Was the motor confirmed to be in good solid running condition when it was purchased?
Did the motor come with the oil pump installed?
Did you confirm that the o-ring on the pickup tube was good?
Is there oil showing on the dip stick?
Is the oil pressure sensor plugged in?
If there is oil in the oil pan, get an analog oil pressure gauge and see for sure where you’re at for oil pressure.
T
tneels
I purchased a used engine from a auto salvage yard that said it was in good working order when they took it out. They ship used engines daily. We installed a new oil pump when we installed the engine And a new pick up tube oil and oil filter oil pressure sensor is new and all wires are connected.
T
tneels
Yes we purchased a used engine from a salvage yard that ships used engines daily. We installed a new oil pump, oil pick up tube, filter, oil , oil sensor, checked the screen on the oil pressure sensor and the wiring and still no oil pressure. Bought a oil pressure test kit today and going to remove the oil pressure sensor and hook it up next to see if it reads anything. Is there something I'm missing or what could it be
smokymtn65
East TN
Is it running with no oil pressure? or are you cranking it looking for oil pressure? If you didn't prime the pump it will never get oil pressure cranking it.
T
tneels
WE STARTED TO JUST CRANK IT OVER WITHOUT IT FIRING. then started it and no oil pressure. How am I supposed to prime it. We cranked it over quite a few times without it firing to try to prove it. Is there a certain way to get it to prove
T
tneels
is there a certain way to get it to prime
moved
T
tneels
how do you prime the oil pump
Geotrash
Dave
Richmond, VA
When I installed a new oil pump on my Yukon, I removed the front cover of the pump and packed it about 25% full of synthetic grease to seal the rotor/housing gaps. Worked perfectly. You can do this without pulling the pan - just need to remove the harmonic balancer and timing cover, and anything in the way of getting them off.
smokymtn65
East TN
Right side of front of motor down near the oil pump is a plug you can pull out and pump some oil in there. I will try to find the link I found before on it
T
tneels
I saw a video on that but what do I do after I fill that with oil
T
tneels
After I fill the oil pump with oil from the side port how should I proceed with continuing the prime and I am going to remove the oil pressure sensor and put an oil pressure test Guage on it after I do that and remove the Guage will I have to reprime the engine
Foggy
KS
Melling website has a video on how to prime LS style engines..
worked perfectly for me last time I did a pump/ timing chain replace
ibarra503
