TRANSMISSION Oil Cooler Retrofit
2007YukonXL
This is a similar question to my post on the ENGINE oil cooler retrofit...
My 2007 GMC Yukon does not have an external TRANSMISSION oil cooler as it only has the radiator tranny oil cooler fittings.
Has anyone installed an external transmission oil cooler? T
Is there a kit available with the oil cooler that mounts in front of the radiator and lines pre-made I might go that route.
Any suggestions, advice, pictures, or well wishing would be appreciated!!!
THANKS
THANKS
I'll be doing this when I remove my bumper cover/grille to replace my headlights. I have a Tru-Cool Max LPD47391 kit on deck for this. I might get the OEM HD trans cooler hose set and modify it so I'll have hard line ran the whole way.
THANKS
If you decide on the OE route:
1 Transmission Oil Cooler 20880895
1 Inlet Pipe 25999420
1 Outlet Pipe 15779543
1 Retainer 15049288
Bill 1960
Testing the Limits
If you do the OEM return line, be aware the connector on the side of the trans is very difficult to access. Need a small left hand to remove and reinstall the retaining clip. Or drop the exhaust.
Monz11
Da Burg, Fl
THANKS[/QUOTE]
I would purchase this bracket: https://atomicfabandperformance.com/product/trucool-40k-trans-cooler-mount/
Also, there engine mounts are superior!!
Monz11
Da Burg, Fl
Chris, what about aftermarket hoses, from Vibrant - they are poly and never need replacing in our southern heat!!
2007YukonXL
Thanks for the advice.
Using hard (aluminum) lines is better than rubber or PTFE because the aluminum acts like a supplemental radiator and dissipates heat while the fluid is flowing through the lines.
I haven't looked into it this far yet. Thank you for the notice.
I'm not familiar with them. I've made lines from quality bulk hose and stainless worm drive hose clamps and had them last 15+ years. I wouldn't hesitate to use them on this, but if I can have factory hard lines the whole way, I'd rather go that route. AFAIK, all that's needed for the Tru-Cool 40K is a splice fitting so you can cut the left side pipe (when facing engine) and reattach it rotated 180°.
Geotrash
Dave
Richmond, VA
I'm not familiar with them. I've had quality oil lines and stainless worm drive hose clamps last 15+ years. I wouldn't hesitate to use them on this, but if I can have factory hard lines the whole way, I'd rather go that route. AFAIK, all that's needed for the Tru-Cool 40K is a splice fitting so you can cut the left side pipe (when facing engine) and reattach it rotated 180°.
Yes, this is correct, Chris.
That said, I think if I had it to do over again, I would go with a Derale transmission cooler with its own fan, and mount it either below the radiator, or somewhere else that's out of the way. The challenge I'm having with the Tru-Cool is that while it's super effective, it also reduces the airflow through the radiator, while increasing the temperature of that air, creating engine cooling problems when towing in warm weather, and necessitating a radiator upgrade in my case. It's possible that I would've needed a radiator upgrade anyway for the kind of towing I do, but either way, putting the heat from the transmission cooler in front of most of the radiator makes the whole cooling system less efficient, and really doesn't make good engineering sense.
Foggy
KS
I'm in the process of putting in the Derale trans cooler with it's own fan too.
My trans runs a little hotter than I'd like and I think the reason is that my intercooler
for the supercharger is directly in front of the oem external cooler..
So moving that should help airflow to everything else and not having hot
air going directly into the aux trans cooler should help too
Bill 1960
Testing the Limits
That’s a good point, and just to clarify the OEM lines are steel. Aluminum would be fragile in that size.
thompsoj22
Consider running the DERALE as a stand alone cooler. By design they are intended to be used "stand alone". I kept the radiator in the circuit on mine and feel it isnt necessary at all. Since you are allready concerned with removing heat sources from your engine cooling system this is the way to go. when you cut the line's to plumb the DERALE simply cut the in and out from the factory trans lines to the radiator down low and leave them installed in the radiator zip tied out of the way. In the event you end up living in Vail and want the trans heat from the radiator it is easily plumbed back in with clamps and hoses.
2007YukonXL
THANKS for the clarification and keeping me honest.
So I have seen there is a transmission cooler that is mounted in front of the radiator and condenser on a bracket. T
https://transmissioncoolerguide.com/best-transmission-coolers-silverado-sierra/
His looks like an OEM device so the questions are...
-Is this a bolt on kit or is it a universal type deal that I need to fabricate?
-Is it plumbed after the internal radiator cooler or is it used in lieu of the internal radiator cooler?
-Regarding the STEEL lines (see learning has taken place), to install the external trans cooler in front of the radiator does the kit designed so that you un-plug the steel line from the outlet of the radiator cooler and then connect the kit supplied steel lines up to the new cooler in front of the radiator and then it contains a second steel line that returns to the now loose end of the return steel line?
Thanks in advance for whatever advice you can throw my way!!!
Bill 1960
Testing the Limits
See the link in post #2, I just did what you’re asking about. That’s the OEM cooler in the picture in your link. You can buy everything at the dealer, or use online sources to buy it. That’s 100% bolt on using factory parts.
In the factory configuration, it runs to the radiator, then out of that to the front air cooler, then returns to the trans. There’s a short line to install from the radiator top connection to the air cooler. The return line goes from the air cooler all the way back to the trans. The original return line is removed and discarded.
A practical person might decide to cut the original return line and splice in just a part of the new return, because it’s not easy to remove and reinstall the connection on the trans. Space is very tight.
Not many people will install the OEM equipment because aftermarket is less expensive and cools more, if you get a big one.
trailblazer
Trans cooler output AT at the trans is VERY tight due to the front driveshaft. I used the original fitting and used my brake flaring tool (bubble flare) to keep the hoses from slipping off.
Monz11
Da Burg, Fl
Wish I would have had this knowledge before I changed my mind and thought TruCool would be a better option than the Derale.
Now I guess I'm going sell my TruCool or send it back
CrackerJack135
