Changing to a non computer controlled engine
3Bignewfiedogs
Does anybody know, can you put a non computer controlled engine into a 2001 Denali and still have the AWD work? My current 6.0 with 220k miles is starting to shows signs it is headed to the great round-up in the sky. I have a stroked 383 that I was going to put into my 77 Nova Rally but if I can put it into the Denali and have the AWD work, I'd rather do that. I hate having AWD since I can't select what and when I want to 4x4 however, changing to the selectable 4x4 (like on my Silverado) is way too expensive. At least until I can find a donor vehicle for cheap/free then I can swap it over. But for now, my concern is the engine and having ,my options ready for whenever it finally goes. My son, also a mechanic (and he refuses to be called a technician, he actually can diagnose a vehicle without referring to a computer for everything lol) has suggested putting in the 383 and changing the trans to an older 350 hydro with an electric or manual transfer case. This allows me to select 4x4 at my choosing however, I won't be able to lock the front axles since there is no solenoid on this AWS. Thanks for any suggestions.
GMT800 2005 Tahoe Z71
Navy Supporting Member
Welcome to the forum from Oregon. I agree with @swathdiver.
By the way, after 35+ years in the auto repair industry I learned to call my wrencher's techs but most still preferred the word mechanic. That is what they grew up being called and that is what they like. I was told by a mechanic once that the difference is that mechanic's get dirty and techs wear white coats.
There's so much more than just having a running engine that relies on the complete electronic system. You'd be opening up one hell of a can of worms, but it's not impossible. As James said, rebuild or swap in a new long block and be done with it, plug-and-play. No loss of anything and no major reconstruction just to have a functioning vehicle.
drakon543
assuming your state allows this kind of swap? or was this not part of the your project not put up for discussion. your basically removing everything emissions related by doing this swap and is frowned upon most places. i know everything is up for debate when more power is desired but have you looked into your state laws regarding this swap? depending on where your at in my state(pa) you would never get an inspection sticker on it. well through legitimate methods atleast as certain counties require emissions testing. with no engine hooked up to the computer it would be an automatic fail. id save that 383 for the vehicle it was meant for and if you really want more out of your truck pull the engine and have it worked over and rebuilt. a good reputable shop can easily handle getting more power from it and keep it mild to keep reliability in the mix.
3Bignewfiedogs
Might all that work be more work and time than simply rebuilding or tossing in a used engine?
A reman engine is about $4k here and a junk yard engine is $3500 w/a $400 core charge (WTF, a core at auto wrecker???). And to rebuild will cost about $3000. I spent $6500 building this 383 and seems like a good use for the Yukon money wise. As long as changes that may need to be made don't go over what a reman/used/rebuild would cost. and more power/easier to fix in the future too. Thanks for your input.
What you will spend the most time on is adapting everything to hook up to that engine and of course "rig" many things. First thought, do the motor mounts drop right in and bolt up?
1BADI5
DMV
Might as well go find a 79 Suburban if you want a non-computer controlled engine.
The transmission and transfer case are computer controlled too; guess you could gut the truck and use a 700R4 trans and NP241 manual transfer case.
Again, better off with another platform for the cost and labor involved
I take it that this 383 is an SBC and not an LS?
ks03
Fool Excess Member
Someone who knows better feel free to chime in, but I was thinking a 2001 Denali had a viscous coupler in the transfer case, so you might be up to 2wheels pushing. You could add a locker or limited slip in back for 3 wheels. I thought all the NBS front axles were open diff, the “4wd” ones with the actuator are open, the solenoid just allows the right axle to be connected.
Maybe forget AWD, a little mod on the rear diff, and you might be as well off as any 4wd NBS
drakon543
ive never has to use the services of a reman engine from a web company but a simple Google search for your engine brings up alot of options for used 1500-2k range or remans for 3k some listing it as free shipping and warranties to boot. but anyway back to your main question yes technically you can. however you might as well gut the entire truck as the majority of your wiring is completely useless. your ignition key is going to try to power everything up and you would be removing half of it. so nothing on your dash would work as its all routed through the computer. a custom gauge cluster would be needed or an expensive custom wiring setup with some kind of signal converter to get the computer to register what the engine is doing so it operates the factory gauges. abs is also gone as that requires signals from the factory speed sensors and probably also signals from the engine for the computer to even initialize the abs system. you mentioned 6500 for the engine you built then you going to need a transmission because the transmission you currently have in the truck wont work without the computer and the signals from the engine. the cost of completing the swap to the 383 not including the 6500 you spent on building the engine will probably come close or exceed the cost of buying a second denali.
MojoPaul
Bad idea if you are in any way planning on having the vehicle registered for street use. What you suggest is really just like converting to the drivetrain from a mid 70 or early 80s 3/4 ton truck or burb. Better off to buy an old wheeler and put in that old school 383.
3Bignewfiedogs
Thanks for your input. I can keep the computer up and running the vehicle, just nit the engine. My basic qustion is if the AWD take any input from the engine or just from the transmission. If from the engine, I'll have to rethink the problem. If just from the transmission and wheels, I can do the swap. I've done custom work for years. First one was putting a stroked Chevy #%0 w/a 350 Turbo transmissions, into a Pontiac Ventura wagon (read Vega). Got hooked on weird conversions with that one and have done well over 200 in my career. And if I can put my non computer controlled engine into the Yukon, I WILL rebuild the original engine at my leisure and that put it back as a later date. Therefore not having my dog vehicle out of service
3Bignewfiedogs
I HAPPEN TO LIKE THOSE OLD VEHICLES BETTER THAN MOST OF TODAY'S NANNY CARS THAT DO EVERYTHING FOR YOU AND THE DRIVER'S DON'T HAVE ANY SKILLS ANYMORE. VERY SAD. i HAVE PEOPLE TRY TO BORROW MY 81 f150 FLATBED FOR MOVING BUT CAN'T AS THEY DON'T KNOW HOW TO DRIVE A MANUAL. AND IT IS A 3 ON THE TREE WHICH MAKES IT EVEN HARDER FOR THEM TO LEARN AT LEAST i DON'T WORRY ABOUT HAVING IT STOLEN OR ANY OF MY OTHER MANUAL CARS/TRUCKS.PLUS I HATE COMPUTERS BUT HAVE LEARNED TO TOLERATE/LIVE WITH THEM. BTW, SORRY FOR THE ALL CAPS AS MY CAP LOCK IS STUCK ON.
3Bignewfiedogs
Not an issue as I can fabricate mounts if need be. Good catch though. The trans will bolts right up to the engine so no issue there. It helps I have over 40 years wrenching and tools and welders up the Wazzu (I'm from PNW too lol). MIG, TIG, Stick, Gas and plasma so I can fab up most anything I need.
3Bignewfiedogs
If you aren't retired like me, you will discover that projects like this are fun and I have nothing else to do. Well, walk the dogs and work on one of the many other vehicles around here. I'd like to keep the Yukon on the street since it is my dog hauling vehicle. I plan to rebuild the original 6.0 and throw it back in but with my non computer controlled, I can take my time and not rush to get it back online. And since I have this engine sitting here all pretty and ready to go, I figured I could drop it and rebuild my leisure over the next few months.
3Bignewfiedogs
Thanks. I really want to ditch the AWD and put in a selectable 4x4. I may have a 2001 Tahoe as a donor that I can just pull the wiring and front end/transfer case and be able to use 4 wheels when I want, not a $!*&%^ computer. The swapping in my non computer controlled engine and keeping the AWD working is a moot point.
3Bignewfiedogs
Shared this with my son and he agreed. He works on big trucks and other large vehicles. Worked in my shop as a kid and did his first oil change in 2nd grade. He thinks technicians can't think and need a computer to tell them what to fix. He refers to them as installers and not a real mechanic. His words not mine lol. I do agree the new generation does have a hard time trouble shooting a problem unless they can use their computers.
ThisIsLivin
I'm all for old fashioned carburetor NA motors. But so much in you vehicle is driven of the ECM and engine feedback. You'll need to change out the fuel pump or at least come up with a ton of mods and regulator to make it work. I believe there is an extra bolt on the trans for the LS and without the bell housing will crack if you put serious power to it. Then there is the trans control. You'll spend more time and money trying to make that swap work than rebuilding what you have. There are so many companies building LS long blocks I'm sure you can find something reasonable.
johnsonwillie199
