Sparksalot
Doh! I forgot that was a separate warning.That makes the abs light come on?
On thecopcar its the steering position sensor that does it.
It doesn’t matter. Black lines matter!! I try to leave em wherever I go!One issue with that frame of mind, you don't know if I'm full of shit.
My one bad neighbor tells people how bad I am, and what a victim he is.
and in return people then treat me like shit for it, drive real slow in front of my house after visiting him etc.
Something i realized after i took the side of my sister in law one night, with out even knowing the whole story.
However, i appreciate it.
Eta: well i can show you the footage, and i recorded the conversation i had with the guy afterwards.
I can also proove i took the pew off before i walked over to chat with him.
So i retract my statement.
Just something to keep in mind.![]()
Found the other end of my dangling pigtail. One of the fans. I had noticed the cooling was different since the recall and fan upgrade last year. Darn plug won't stay in, and since it plugs in from the bottom gravity is not my friend. A few well placed auxilliary retainers and all should be good.
Auxiliary retainers sounds more technical. Lol.Pssst in my world ZIP TIES!
I just replaced all my compressor air lines. I didn’t have a problem with the clips, but getting the new hose connectors to seat was hard. I had to use dish soap. Once the connectors are all the way seated, I just popped the clips on.Replaced the serpentine and a/c belt, along with the tensioner and idler pulley. Bought it as a kit last month because in cold weather my tensioner/belt makes a funny noise.
The belts actually looked decent, no cracks in the ribs, so I'm keeping them as backups. Who knows when they were replaced last. I bought the vehicle in August 2018 with 105k on it. One owner trade-in on new vehicle at GMC dealership, so they might've replaced them before they put it up for sale.
Took me a while to figure out the Lisle stretch belt tool to get the old belt off and new belt on. I was just going to cut off the old belt, but the numbers stamped on it indicating the length was about 2" longer than the new one, so I wanted to save it in-case the new one didn't fit and I could put the old one back on.
Also replaced the autoride air compressor. Those metal wire clips that secure the air lines are little bitches to get back on the connector if it pops off. I had two of them do that and after spending about 20 mins f*ing with it finally figured out a way that worked well and was able to do the other one in like a minute...lol.
All total took about 2 hours
How does it hold the phone while vertical like that?
Perfectly!How does it hold the phone while vertical like that?
I think that's a splash shield. I don't think the plastic would hold up well as an actual skid plate.
Its a magnetic charger. I have an iPhone 12 mini in a life-proof case.How does it hold the phone while vertical like that?
I was wondering if it's magnetic or what. Then was wondering how the phone magnetically stuck to it and was still able to charge. Those stick on metal rings answer my question.Its a magnetic charger. I have an iPhone 12 mini in a life-proof case.
I bought this charger but came with a vent clamp. All the balls for these mounts are the same so I picked up these and swapped the stick on base to the charger and mounted it to the side of the head unit. I needed to add a magnet ring to the back of my case so I used one of these on the back of the case. I am powering this setup with this 21w adapter.
Yes, when the clips are on the ends, but when the clip is off, totally out of the slot, it's a bit more difficult.I just rotate the little metal clips out of the groove to remove them, then spin them back into the grooves before reinstalling them.
