6.2 swap thread
mikeyss
Longmont, Colorado.
No clue if it makes a difference, but bought a 90mm TB.
I have been deciding on whether to get a larger throttle body for mine as well. From what I have read, they can add a little more power, but the tune will have to be adjusted to take advantage of it.
L
ls1frc
Still at body shop. Been driving an Audi Q5 for a couple weeks. Not bad, but I miss having the giant vehicle. Drivers out there are absolutely insane.
L
ls1frc
Got the yukon back finally. Feels like driving a literal land yacht after the audi lol.
I went to go do a 0-60 run for fun and I accidentally did a 6000 rpm burnout lmfao. I never did a 0-60 with TCS and stabilitrak off. I forgot I was in 2wd mode, tached it up to 2300 and let it rip. Immediately squeeled and revved up to 6000 rpms. I just went home after that lol.
One thing I have noticed is I haven't heard my air compressor kick on in a while. The shocks felt firm still, but I thought it was supposed to bleed the air out and kick on every key turn? Maybe the Dorman is different idk.
Geotrash
Dave
Richmond, VA
The Dorman is different. It doesn’t run the self check and kick on with every key turn like the OEM pump does. But it does kick in when I hook up the camper and the back end sags. Brings it right back to level. Took me a while to figure that out.
L
ls1frc
Thank you for that, saved me from wasting my time.
L
ls1frc
Its funny how quickly you get used to power. One of the worst things about modding.
I swore my truck felt weak and thought something was wrong. So I got my hptuners out and timed a 0-60 run.
Felt like it was crawling to 60.
Subtracted end time minus start time and got 5.36 seconds. Thats a full 2 seconds faster than my modded 5.3 was.
I guess the sheer weight of the vehicle makes it hard to feel the difference.
It's tough, almost impossible to judge performance increases by the seat of your pants, it must be measured.
I put a set of drag radials on my Buick once, snatched the left front tire off the ground but lost three tenths and 3 miles an hour through the traps. Same thing happened with a 9" high stall torque converter. Felt great but were duds performance wise.
L
ls1frc
Yes my butt dyno is terrible. I had the same experience putting 4.10s in my old C5. It felt ridiculously fast, but it went no faster from a low roll. I still got smoked by my buddies CTSV lol.
Then I put the 3.42s back in but added more power (felt slower) and then beat him.
L
ls1frc
One thing I am not liking is my coolant temps seem too high with the replacement mishimoto.
I am consistently 208-216 and it's only 45-50 degrees outside. Fans even kick on periodically.
My radiator cap was bad (it literally fell apart) and I just replaced that, so maybe some air got in there. Also when I did the water pump, I got the professional not the OEM replacement AC/Delco.
Any suggestions?
Edit
Wow looking at the reviews of the professional pump version, lot of 1 stars. I think I will replace it with the OEM for peace of mind since I am going on a road trip soon.
https://www.amazon.com/ACDelco-252-...uPWNsaWNrUmVkaXJlY3QmZG9Ob3RMb2dDbGljaz10cnVl
Any suggestions?
It's an LS engine- Your rad would have to be pretty bad to make it run hot!
Also, it's an LS engine- An air bubble will make it peg the gauge. :rolleyes:
When it's at hot operating temperature, see if the upper rad hose is firm.
Just Fishing
Can't fix stupid
Utah
I took my vette out the other day, been a while and i decided i neesed to get everything warm and boil off any condensation in the fluids.
It felt slower than my tahoe for some reason.
I passed people like they were standing still, but i guess i just don't get the suspension squat like the hoe does.
And that vette does 0-60 in the high 3's-low 4s
:cool:
(Pretty fkn good for a C4)
Just Fishing
Can't fix stupid
Utah
Mmm carpart.
Found some 6.2's and 6.0's for around 3k
:hmmm2:
I also see a wall of mileage that's identical to a bunch of different sellers.
Sounds totally legit.
:yaoface2:
L
ls1frc
When I bought mine, I found a bunch with that price. Then I search reviews of the junkyards and they came back 1 stars. Also most places require a core back to them or they add on another core charge.
I found a place with 5 stars and made them an offer of $3500 shipped and they took it.
L
ls1frc
Gettin truck ready for a road trip to Williamsburg.
Got some new brakes coming. I just went with the Centric premium with ceramic pads. Got all redline fluids for the diffs and transfer case as well. Pretty sure my transfer case has had the autotrac2 in it for like 50k miles, whoops. I'll do that + change the water pump just in case along with a fresh battery. Still on same battery I bought truck with back in '17. I get the service battery message occasionally so it's probably time.
This is the first long test with the new engine though other than sounding awful on winter cold starts, it's had zero problems.
007matman
I have the 6.2 in an Escalade.
It runs hot when it's working hard. There is a dual-fan setup out there.. did you do that? How about an oil cooler? Sounds like you already did the radiator swap..
Sent from my Pixel 3 XL using Tapatalk
BadDaddy2003
