Yeah, I forgot to put it back in when I removed and cleaned the reservoir, was trying to figure out if that had anything to do with the brakes being a bit different, however, no lights came on.Likely a low fluid indicator. Is there one on your rig?
I removed reservoir from master cylinder to clean it, I forgot to reinstall sensor.There is typically a float inside the reservoir that when gets low enough it triggers a signal sent out thru the wire to your dash.
By put it back in, are you saying you already have another master cylinder and the one you got did not have that plug in? The ones I sent you a pic of already have the plug in at the reservoir and all you do is plug the wire in.
That screenshot of parts are clutch hydraulics...not brakes.
