FYI Fumoto Oil Drain Valve
Jason in DLH
Cheeseburger and Fries
MN
Installed the Fumoto Oil drain valve 12mm-1.75 threads tonight. It will definitely make changing the oil a little less messy and easier. I got the F107N (N stands for the added nipple) with a locking clip. One downside is I couldn’t thread it so the valve lever is visible, but doesn’t matter...still is super easy to open the valve, shut it, and lock it. Some pictures...
They make a cap for the nipple, but forgot to order it. Will be adding that soon!
STORMIN08
i wouldnt mind the valve being hidden/protected... simply add a piece of hose and no mess
Bandit-66
i'm not quite sure if all these systems do anything, except of course the clean finger.
because through the valve the drainage cross-section is reduced and thus the oil runs out slower and possibly, the abrasion and oil sludge do not bring out so, since the system is also something after in it.
there is always some residue in the pan,
tsuintx
DFW
Been thinking about adding a Fumoto in a lot of my vehicles over the years, just never got to doing it. Maybe I finally should find it in me to actually do it. LOL!
I have no issue doing the oil change the old-fashioned way, either, but Fumoto sure would make the draining a lot easier.
Tonyv__
Bucks county PA
I kinda agree. Not from experience but the idea of something threaded into the hole now creates a lip
I really like the idea but I can’t not think about this now lol
Pittz
Been using the Fumoto since 2016. Not a single issue and makes oil changes so muc easier and cleaner. I would not be happy if someone brought one in to me if I were a Indy. It does take a lot longer to drain.
Jason in DLH
Jason in DLH
MN
Yeah...I thought about the residue as well. Perhaps after a couple oil change intervals I’ll unscrew it to see what kind of buildup there is.
Tiredmechanic23
heavy equipment manufacturers have used their own versions of these from factory for years with 0 issues on machines that see constant heavy duty use and poor maintenance. Still no issues. These will not cause a problem.
Jason in DLH
Jason in DLH
MN
Great to know, thanks!
BG1988
is the valve heat rated?
08grey
I've got some stainless one made by a veteran with a ball bearing for a stop i forget which brand it is but its nice. You just screw in the end with the hose attached and it drains.
Sent from my SM-G973U1 using Tapatalk
08grey
Its called a valvomax
the_tool_man
Upstate South Carolina
I put a Fumoto valve on my Yukon a while back. I've used it for three oil changes. It does take a long time to drain. But it's nice not having to use any tools for it. So I just go do something else while it drains.
BeenChevy
Minnesota
Which model Fumoto did you go with? F137n?
Always making a mess pulling the plug on this truck. Such a squirter. The 4x8 cardboard and 2 drain pans still sends ejecta on the wheels, arms, face..
BeenChevy
Minnesota
Glad to hear it. Model F137n appears to be the right one. Picked up some 3/8 tubing to go along with it. Just have to turn the truck upside down like usual and install it so oil doesn't spill.
Bagherra
Army
Va Beach, VA
When i first got my '16 Denali, i installed a magnetic drain plug cuz i like to try to get most of the fuzz out....but i think i'm go with this....
so F107N or F137N is what i need?
BeenChevy
Minnesota
F137N supersedes F107N. It features a larger internal orifice which allows for a faster oil flow
Merch619
