Best Place To Jack Up Engine
22YukonDenali22
Hey All,
I'm going to be changing both front motor mounts soon on my 2008 GMC Yukon Denali, 6.2, RWD. What's the best/least damage-potential area for using a floor jack with wooden 2x4's to slowly lift the engine?
Tonyv__
Bucks county PA
Not gonna lie. I did my Sierra a few years ago and lifted it with a 2x4 across the oil pan. Probably not recommend. But it worked and no future problems... I don’t know if there’s any good jack points from the bottom of the engine. You might need an engine lift
22YukonDenali22
Thanks Tonyv. Did you loosen the transmission mount at all? Not sure if that would be useful...
Tonyv__
Bucks county PA
If I remember correctly yes. And I had to remove the steering shaft in the engine bay. It’s tight as shit trying to get the mount in there. I only did my driver side though. Should of did both but it was a work truck and I didn’t keep it long.
kbuskill
NE. FL.
Thanks for the info Tonyv!
There are actually spots cast into both sides of the engine block that protrude out specifically for this.
22YukonDenali22
View attachment 268969[/QUOTE]
Dang, I have power steering cooler lines blocking that tab, and the passenger side looks like almost no access to the tags without removing a bunch of stuff...
kbuskill
NE. FL.
When I did all the work of dropping the pan and swapping oil pump and timing chain, etc. back in the day I used a engine hoist/cherry picker, but a piece of 2x4 stood on its end between the jack and the jacking points on the block should work just fine as well.
My Burb is a 2wd though so I know there is less stuff in the way.
kbuskill
NE. FL.
I knew the oil pan was a no no but I didn’t know the jacking points were there either. I just assume engine lift was the best/safest option
Down side to using a traditional engine hoist is the legs sticking under the truck are kind of in the way when you are under there.
But if you extend the arm out on the hoist and keep the lags pulled in its not too bad. Just MAKE SURE that you have enough weight on the back of the hoist so it doesn't tip over.
wsteele
Hey All,
Here is one on Youtube. Not sure I would have the courage the use the cat as a hoist point, but...
thompsoj22
Good mech with skills. But, The jacking point is based upon hope/luck and it worked this time! In the event it didnt, Lets say exhaust bolt at the engine or pipe to manifold breaks/shears would he inform the owner? would he fix it if he had to remove the manifold and easy out the shank from the engine block? Yea probably not, Im not hacking on the guy, just realizing that dropping your car off with a " professional" dosent mean you get "factory service techniques".
wsteele
Yeah, I actually had a momentary flashback to that DC10 crash out of O'hare where an engine fell off just after takeoff. I did like the rest of his process though. Might give it a try myself when the time arrives, sans cat jacking. Seems like a cherry picker could be pressed into service pretty easily and eliminate cracked cats, broken manifold unions, etc.
1BADI5
DMV
I did both of my mounts in the driveway with the front wheels on ramps.
- Driver side I was able to do without lifting the motor (mount came out in 2 pieces, I replaced with solid mounts and it was a 2 piece design)
- Pass Side, I dropped the starter out and I lifted the motor about 1.5" via 2x4s and floorjack under the AC compressor bracket.
NOTE: Common sense goes along ways
John H Daniel
I just did the drivers side and used the oil pan with a board to spread the load. With that nice flat area and the nearby stiffening ribs, its hard to believe its not expected. Though I get that its not recommended. Certainly did it a plenty back in the day with those stamped steel pans. (stop sounding like an old guy...)
Has anyone ever heard of damage from this? Would be good to know.
the_tool_man
Upstate South Carolina
One of the YT videos I watched, the guy took two 2x4's and nailed them together into a "T" cross section. He was just able to insert it between the front drivetrain and the frame to get at what appeared to be a reinforced area of the oil pan. He used a floor jack and the "T" to lift the engine. Here's the vid...
AdrienR
