osiris94ej
Casper Wyoming
Not today but over the course of the weekend. No pictures because phone was busy playing music Friday night, and put the tip on today so ther is that today [emoji2373].
But the ****** is back on.
Sent from my SM-N950U using Tapatalk
Eh. Little ol' 5.3, small cam and crippling 4L60...
Although, after watching it some more, I guess it does seem to still be climbing half-decently well up to around 117. Maybe I'm expecting a little too much from the brick.
I determined the "wall" to be around 125-130ish. I let off when it looked like the RPM climb stalled around 5,600.
Running the math just for fun:
5,600 RPM engine speed
1:1 Third gear trans ratio
3.73 Diff gear ratio
32" Tire (16" radius)
= 142.9 MPH
I know I wasn't going over the low 130s. Hard numbers don't account for slip in the unlocked torque converter.
I just go by the trip computer, either the Garmin or pioneer
Have you still got pictures/diagrams of those handy? This seems like the lowest and easiest solution
Been digging for a minute and can't find them at the moment. However, I did run across this:
https://www.tahoeyukonforum.com/attachments/console-wiring-harness-connection-108-pdf.185222/
It has the wire colors and locations for the speaker signals feeding the Bose. If your wire colors and locations match, you could tap into those wires. I'm not sure if it matters to tap into a front or rear pair. I'd tap the front, assuming it has the most full-range sound. Your amp's built-in crossover will filter out the mids and highs. Cut and strip the wires, cut and strip some RCAs (female ends), solder them accordingly (center of the RCA is +). Don't forget the heat shrink. Then, just plug regular RCA cables to them and route 'em to your amp as you would if you plugged the RCAs to the back of an aftermarket HU.
*EDIT*
Just found this. Might wanna research it first. Apparently, the "A" at the end denotes that it is for those vehicles with the Bose amp: https://www.sonicelectronix.com/item-18700-PAC-AOEM-GM1416A.html
PG01
Up here to the right
Is the retrofit door itself available separately? It's not a difficult job to perform. Or, get the whole retrofit kit and you'll have a replacement filter on hand already.
Yes, it used to be anyway. When I did mine back in ‘14 chevy did me the same dirty way... sold me the filter then I had to source the door. Pretty sure Amazon had just the door and I probably paid 2x the amt but meh, it is wut it was....
Can you check that 6+ year-old pile of parts in your garage for that door to get a part number, please?
Just Fishing
Can't fix stupid
Utah
I have been finding that i can source the door and the filter, but i haven't seen a good listing for just the filter.
Also adding the cabin filter was an awesome addition.
now when i go off-road, i don't get dust blowing through the vents. :cool:
No scared of driveshaft explosion?
although driveshaft problems have occurred as reported by other members, the question arises about the ppv's I don't think they use a special driveline and they are usually programmed for almost max speed. I have driven a multitude of miles at max speed and never batted an eye at the driveshaft, tires on the other hand should be speed rated.
ls1frc
I just checked mine it's rusted to shit and a magnet sticks to it. I thought these were aluminum.
ls1frc
It's steel. Now I'm trying to think of what vehicle I had or at least was under a lot that had an aluminum shaft.
Oh well, I rarely ever visit Mexico and I doubt I'll ever take this rig above the 120s. But I'll be sure my U-joints are of good quality and in top shape regardless.
Did not age well LOL!
ls1frc
Yup my Yukon is steel then. Cool, finally something I don't have to upgrade! I just wanted to be able to trap 105-110 in the 1/4 safely. No intentions of higher than that on the street.
kbuskill
NE. FL.
GM 22759208
https://www.amazon.com/dp/B01G5VHFW8/ref=cm_sw_r_u_apa_fabc_7JOZFbMW3CA5Y
I got mine a month or so back and it was like $19 shipped.
This is the filter that I installed...
https://www.amazon.com/dp/B089T4ZC7Q/ref=cm_sw_r_u_apa_fabc_uMOZFbZ25BCBN?_encoding=UTF8&psc=1
It is an activated charcoal filter with baking soda.
Conedaddy
