Mickey_7106
Bay Area
Anyone know how to turn off and keep off the AC when starting the truck with the remote? I dont need cold air blowing on this sunny 62° weather
What shop are you taking your tranny to?
there is a local shop here called "express transmission" there not a performance shop per say but they are the best in town, he does custom stuff on request, they have been real good with warranty and customer service at least in my experience. I have seen some performance cars in there on the racks and he said he built one for a G8 a couple weeks back said that one was $6k ouch....
if you are using the oem remote and have the hvac set to auto it will come on, if you turn off the hvac before you shut it off the night before it should not come back on until you turn it on as far as I know, I have a aftermarket alarm system with remote start so it bypasses oem and my heat/ac will be wherever I set it last or off if turned it off.
Mickey_7106
Bay Area
When i had my C5 i couldn't find any transmission shops that i was comfortable with. Ended up getting one shipped from performabuild
Mickey_7106
Bay Area
Its an oem remote. I'll try that out. Thanks
Just Fishing
Can't fix stupid
Utah
Anyone happen to know of a good forum that talks tuning?
I have a few camshafts in mind, but i need to get an idea of what is really needed to get it running right...
Just Fishing
Can't fix stupid
Utah
https://www.corvetteforum.com/forums/ ? not sure how active it is but seems to be some activity anyway I was on there about a month ago poking around
Thanks, I'm a member there already.
I'll poke around in the C5 and C6 section.
On another note,
Looking at camshafts at TSP, they reference square port heads and cathedral port heads.
any idea what type of heads my 5.3 LMG would have?
ya I have considered just buying one that way but after labor and everything probably be the same price, I have dealt with this guy a few times before after some bad experiences with another shop that has gone out of business, which is no surprise
St. Louis
Not sure if this is the case. It was 22* this morning when I left for work and I used the remote start before I left. When I got in and turned key it was on auto and the snowflake was on. The windshield was a bit frosty so I turned the snowflake off and hit the defrost button and turned the fan up, thus taking it out of auto mode. That's the way it was shut off after getting to work. When leaving work it was in the upper 30's and I remote started it and when I got in and turned the key the controls were back to auto with the snowflake on. DOH!
kbuskill
NE. FL.
On my '08 it doesn't matter what you have the HVAC controls set at, Auto or otherwise, when you remote start.
It basis it's decision on out side temperature.
During cold weather, when in remote start mode, the blower motor will not turn on until a certain engine temperature is reached.
When you get in you may notice the blower going full blast on heat and if you had the A/C on when you last shut the truck off it will resume those settings when you turn the key to Run.
next time that happens see if the temp is then set for 74 on both sides, if it is then you are loosing a connection somewhere, just like when you disconnect the battery the hvac reset's to 74 and auto.
St. Louis
Nope, never have the temp set that high, only like 71 or 72.
maybe it's 72 it's one or the other 72/74, but it shouldn't be going back to auto regardless unless you press the button that would be infuriating for me especially in California where you basically have to have it set to 60 for the entire summer.
