2006 gmc yukon xl slt plus gauge cluster.
Woodblocker55
Woodblocker55
Odo-pro.com
I bought that denali cluster from the junk yard he sold as not test could not power up do to ignition switch. What ever that means .. it looks in perfect shape and it was repaired 2012 says tested on back . anyway my question is can I plug it in to my working 2006 yukon xl to see if it works ?? Could it screw up anything in my working Yukon XL if it was messed up ? It would just not work right as its just a display . Let me know so I can test it to know what's wrong before I ship it off for $99 rebuild ...what's your thoughts ?
Myself I just want gauges all to work first then I guess about mileage stuff . I want that tranny temp gauge for towing .
Sent from my LGL722DL using Tapatalk
Shouldn't hurt anything if you plug it into your truck.
Woodblocker55
Woodblocker55
I tried it works great all gauges were right and 317,000 miles on it pretty shocking .. only issue someone put LEDs in but there pretty dim only the back round lights are the problem . Need changing back to stock lights to match everything else ..
Can the guy at odo add a tranny tempture gauge to my 2006 cluster that doesn't have it ?
And what's normal tranny temp run 150f got it up to 185f when had sit idle for a bit ..
Checking the tranny level is at 150 f right ???
afpj
For my 2002 Yukon 4x4, 5.3 with a 4L60E, manual says to check transmission fluid level at normal operating temps between 180 to 200°. I would hook up a scanner to make sure the gauge reads the same.
Pretty sure he can add the trans gauge. Hit up his site--odo-pro.com. He lists all his services there.
Woodblocker55
Woodblocker55
Yes last night I hooked scanner to it gauge was right mine runs at 152f all the time .. only way I could get warmer let it idle long enough . If take for a ride cools right back down to 152f it's pretty hard to get it to 180 f it idle for long time . I looked at manuel it did not say a tempture to check tranny at in 2006
So I'm confused. At 150 f the tranny levels perfect .. at 180f after idle it's over full . This is level the previous owner had it at . I just copied how he had it after changing tranny lines. ..
Woodblocker55
Woodblocker55
He did a full rebuild of my 04 Esky cluster, with leds and mileage programming for around $125 iirc. That included return shipping.
He said he couldn't add tranny temp gauge to my 2006 cluster..[emoji19][emoji848] At less my other cluster has the tranny temp gauge .
He did mine a little over 3 yrs ago. I could've sworn his site said he offered that service. I know others do offer that service tho. Few on ebay do.
Woodblocker55
Woodblocker55
I will have a look around . Maybe he just don't like doing them .
alaska_guy
Alaska
Yeah, more than likely he just doesn't like programming them. I rebuild clusters locally and easiest way is to buy new eproms, flash them with trans motor settings and then place the new chip on your cluster.
At least that's how I do it.
It's not hard, but takes time. Where about are you located, I know a few guys that run businesses for cluster repairs in the lower and are very reasonable.
PM me.
To help keep trans temps down. I run this stuff in ALL my fleet. Its the ONLY trans additive that trans shops endorse
Put this in my Express van because the shifts were hanging up--even after replacing the solenoids. Shifts beautifully now. Was recommended by my trans guy.
bayareadude84
Methahoma(temporary)
Ya its GOOD stuff !!! There's a big transmission distributor out of Cleveland, Ohio "TruTrans" /Transtar industries and they sell it at LOWEST price on Amazon/Ebay !!
I grab a few 10oz bottles when they have a sale going on
Dave
Hodmjstone
