St. Louis
I painted the whole front with 3M Rubberized paint. I was sick of all the rock chips and I simply didn’t want to spend all the time wet sanding only to have more rock chips in the future. Plan to do the hood, fender flares, mirrors, and lower part of doors to match as well as de-badging the entire vehicle Maybe I’m making a huge mistake, but I’m liking the results so far.
What fender flares do you have?
Circle D has a 4 week build out time on converters right now............. SOB
Mine is scheduled to ship on 13 Nov
Pretty much everybody has at least that much lead time right now for anything built to order. We are going to need patience for a long time due to Covid. Actually 4 weeks isn’t bad right now.
Jason in DLH
Cheeseburger and Fries
MN
I installed Bushwackers on, but they’re not for the Denali (which I have) so I had to trim quite a bit in the rear and the fronts don’t fit perfectly either. I didn’t think there would be so much difference in trim levels.
This is the rear after trimming a lot. I’m going to caulk it and spray the rubberized paint over it so it should look better.
Here is the front (I will be using a self drilling Stainless screw to bring it back to the body and then spraying it with rubberized paint):
Overall they look good. I initially was going to have them gloss black (hence the orange peel that I didn’t sand off yet) and changed my mind to go rubberized coating.
Jason in DLH
MN
Nice! What kind of compressor do you have to run it?
ive got a little compressor, so I went with the Ryobi Cordless impact. Worked well getting the rusted shocks off.
Just Fishing
Can't fix stupid
Utah
I have Quincy QT54 (60 gallon 2 stage)
I love that compressor. :cool:
I have my air setup to do a future paint job on the ol vette.
Once i'm willing to deal with it that is... :anitoof:
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
Mickey_7106
Bay Area
Are the caliper slide pin boots replaceable? I have 2 that have holes and allowing the pin to stick.
Also what pad hardware are you guys running? I broke 2 of those pad stoppers circled below in red. I had bought them from O'Reilly the beginning of this year. The material is pretty weak. Never had one break till now.
89Suburban
SE PA
Good luck, I tried a couple of those kits the dam boot just rips because it has to be pressed in I ended up just buying new calipers, maybe a it takes a special hand but didn't work out for me
The ones that came with my Powerstop kit had no issues like that. I used a poor man's press (socket) and tapped them in that way. Then you got to watch when you grease the pin and slide it in it wants to balloon open. I use a pick tool to hold it open and let the air escape as I slide the pin in.
Buford bubba
