Gather round for a story of mechanical ineptitude and blisters.
Thouse
Please enjoy the following story at the full expense of the skin on my thumb and pointer fingers. TLDR at bottom:
A few months ago speeds 1-4 on my AC/Heat stopped working. I didn't think too much of it at the time as speed 5 still worked and lets be honest--- if I am going to do anything I do it full sendso speed 5 is good enough amiriate? Some time passed and I again became interested in making my Tahoe less of a shitbox. A week or so ago I changed the high/low beam bulbs in my Tahoe so that basically makes me a certified master technician.
I researched what might be wrong with my AC system and settled on a blower motor resistor and watched a baller video on 1A auto's youtube channel on how to change it and figured it was a drop in the bucket compared to my vast mechanical skills (heh). At the same time I decided that I would change some of my interior bulbs over to LED bulbs. I had already changed the front map light bulbs to LED along with the license plate bulbs. All that remained as the middle and rear dome light bulbs.
Today my resistor came in the mail and I was super excited. My wife watched the boy this evening while I grabbed a knee pat and headed out to the driveway with my flathead and 7mm ratchet to change the blower motor resistor. To my horror I found that the 7mm socket was slightly too large for the bolts holding the kick plate up? 6mm was too small. I tried almost every socket I had around that size and none fit! I tried the 1/4 and so on. Like I said I am basically a mechanical genius so I knew what sizes to try (sarcasm).
Defeated and deflated I decided to change the bulbs in my dome lights for an easy win before giving up for the night as it was getting dark. Do you see where this is going?
I clamber into the back seat ready for an easy changeover and reach up and grip the middle dome light bulb with my right thumb and pointer finger and promptly burn the living tar out of them till they blister cause DUH I had the passenger door open for a long ass time trying to get the kick plate off to change my blower motor resistor.
I change the side switch activated dome light bulbs with LEDS- with all the doors closed and then am able to change the middle door activated bulb after a few minutes with no more skin-searing effects.
I changed the back dome with similar hilarity after leaving the barn doors open and reaching in while the dome light was on before climbing in the back and closing the doors so the bulb would cool off. I had no idea halogen bulbs get so DAMN HOT.
I hope you enjoyed the read and I have a serious question below.
TLDR: What do I do to get the kick plate bolts out to change my blower motor resistor on my 2004 Tahoe when 7mm is too big and 6mm is too small? Also plz send aloe cause I have blisters on both thumb and pointer fingers.
Danny3737
You really don’t want to touch halogen bulbs with your finger period. The oil from your fingers can cause them to burn out quicker. If you do, wipe them down with isopropyl alcohol before you turn them on
Don’t feel too bad, we’ve all had those days
Thouse
Thouse
Are you using six point sockets or 12 point? Quality sockets?
the sad part is I didn’t even know this was a thing. They are only 6 point and made in CHYNA no doubt. Can this really make a difference?
HiHoeSilver
Away!
Chicago
This is hilarious! The best stories are definitely the ones where we relay our own stupidity. You had me laughing out loud. I can't remember what size I used taking that kick plate down, but 6mm sounds right.
Maybe they have been removed before and that person rounded them off? It's kind of a pain, but you could just grab them with a pair of pliers. That's what a dealership tech would probably do anyways if the pliers were closer that the ratchet. Then you'd be a real pro!
Edit: Thread title of the year nominee.
drakon543
there is a 6.5mm also
it wouldn't be the first time i was working on something and what was supposed to be there wasnt. anyway it sounds like me and you should never work on a vehicle together. there would be an ambulance ride involved with 2 people prone to self inflicted injuries.
Thouse
Thouse
Ha! Amen to that
7mm for the kickplate, 5.5mm for the resistor, just go to the store and get those in a slightly better then dollar tree brand, oh and don't forget some band-aids :rolleyes:
Roger that. They don't seem rounded off but if I am feeling lazy I might just take the pliers route but I will probably end up rounding them off in that case which would bone me or the next guy down the road.
Thank you for the great laugh.
We all learn differently, but the important point is to learn and not repeat the same experiences. Looks like you need a second reinforcement experience to complete the learning process. LOL
Thouse
Thouse
Alright gents. Have some updates. I tried a bunch of different sockets and low and behold the third 7mm socket I tried worked on the kick plate bolts. I only took two out and just spent the entire time kneeling on a towel in my gravel driveway hating life and pushing the semi flexible kick plate out of the way. I swear to god if you ever wanted to do the retrofit cabin air filter1- don't, and 2- take out more kick plate bolts. I did watch a youtube video where the guy used a bungie to hold tension on the kick plate but that would still suck in my opinion.
Everything else went smoothly with one exception. The plug that snaked around to the back of the blower motor was a royal ***** to unclip I tried many different angles and screw driver blades to get it to unclip but finally just brute forced it. The new clip went it and clicked so at least I didn't damage the female end on the blower motor. I dont think the video I watched on 1a auto where he changed it in a suburban the blower motor clip location looked the same but maybe it was..
Now every speed on my blower works! A few images for your entertainment.
Look at this crusty boi
My handywork on the blower motor clip on the old resistor
Lastly a little easter egg found in the kickplate!
I cant find a date on it anywhere but id laugh if it was a winner 15 years ago and they lost it and couldn't find it.
Enjoy your day gents!
George B
¯\_(ツ)_/¯
Oconomowoc, Wisconsin 53066
And given your luck so far the bungee would let go and you would get injured AGAIN!
Glad you got it fixed.
GMT800 2005 Tahoe Z71
Navy Supporting Member
I am an ASE Master Tech and I have the scars to prove it. You are not Baptized in to the Master realm until you have forgotten how tall you are, I am 6'4", and you have a vehicle on the lift and you stand straight up from being in a stoop over and nail your head on something sharp, like maybe a exhaust clamp or a shock mount bolt, and come out of there bleeding like a stuck pig and holding your head with blood running out between your fingers and the other techs laughing their collective asses off at your stupidity. Then and only then are you allowed to speak of your mechanical prowess.
George B
¯\_(ツ)_/¯
I say “It ain’t yours until you bleed on it.” I have truly owned each of my vehicles and donated to many, many more.
"I am an ASE Master Tech and I have the scars to prove it. You are not Baptized in to the Master realm until you have forgotten how tall you are, I am 6'4", and you have a vehicle on the lift and you stand straight up from being in a stoop over and nail your head on something sharp, like maybe a exhaust clamp or a shock mount bolt, and come out of there bleeding like a stuck pig and holding your head with blood running out between your fingers and the other techs laughing their collective asses off at your stupidity. Then and only then are you allowed to speak of your mechanical prowess."
Or, like my youngest son, who attempted to pull the shifter knob off of the shifter stick on his Ford Ranger. He figured out that maximum leverage was needed, so he got down over it and pulled it with all of his might. And, the knob came off, straight up into his face, and he had a black eye for over 2 weeks. He did learn, though.
Oh yea. I once was trying to unhook a park brake cable from a rear caliper and was using a pair of needle nose pliers to do so. I was puling pretty hard and the pliers slipped off and came right at my face and I stabbed my right cheek with the pointed end. Could have lost an eye if was 2" higher. That bled like crazy too.
drakon543
im all set there then and does ripping your head open multiple times upgrade you to a guru or sage level? old motorhomes had a metal trim around the wheel wells that was just cut off razor sharp. i stood right up into that and got to get some nifty staples in my head. the other times wasn't quite so bad and let it do its own thing.
Blood is a badge of honor for sure. I am just thankful I have all my fingers in tact.
justinakay79
