Upgrading to LED high beam and low beam bulbs on 2015-2020 Tahoe
TahoeTex
Haven’t found a definitive post about which specific bulbs worked well in a 2015-2020 Tahoe, so I hope this will help.
I installed the same bulbs I upgraded my 2017 CR-V with (took them out before I sold it). They are the same exact size and work amazingly well in the Tahoe as well.
Low beam: HIKARI Ultra LED Headlight Bulbs Conversion Kit -H11 (H8,H9), Prime LED 12000lm 6K Cool White,2 Yr Warranty https://www.amazon.com/dp/B077BT6M6Z/ref=cm_sw_r_cp_apip_DfMom7x2O6Bw7
High beam: NINEO 9005 HB3 LED Headlight Bulbs - CREE Chips - 12000Lm 6500K Extremely Bright All-in-One Conversion Kit,360 Degree Adjustable Beam Angle https://www.amazon.com/dp/B07JCSRS7H/ref=cm_sw_r_cp_apip_t5PNiP6lAz2gZ
tjmclea
I know this thread is old but I am hoping somebody can give some insight. I just purchased Hikari Lows and Highs for my wifes 2015 Yukon SLE. The lows work great, but the highs don't function at all. If I put the old Halogen bulb back in they work. Has anybody seen this issue before?
STORMIN08
they may be polarity sensitive, you may have to repin the connector...
or cut the wires and swap the leads, however you prefer to go about it.
vtxtexan
