992dr
Eastern N.C.
Two things =
Its nice to be able to get in and out of the Tahoe without hearing that ridiculous grinding from the jacked up door pin.
What a relief to not hear that clunking in the steering after replacing the ISS. Lock to lock without a grind or a clunk, nice.
wjburken
Eastern Iowa
Two things =
It’s definitely the little things sometimes that can make a big difference.
DurrtyBurB
AZ
what kit is on it maybe I will take it off your hands
Actually no idea, 15” rotors and caliper spacer
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
My guess it wont open no matter what you do until the wiper motor is replaced and wiper arm is installed properly in the parked position, it's a safety interlock so you can't open the rear glass and then whack yourself with the wiper arm in the process.
Sounds reasonable. I will pull everything apart again and plug the motor in to confirm. I may have to “phantom mount’ the motor in the door panel somehow until I can get my hands on a wire diagram and find a way to bypass it.
that "might" work IF the wiper was still in the parked position when you unplugged it and if you don't accidentally turn on the rear wiper and throw it out of whack.
89Suburban
SE PA
Theoretically the motor should return to the self park position by itself shouldn't it? Of course we are getting thunderstorms so this should be fun.
without the parking stop being there not sure, people have had problem with the rear glass not opening and it is usually because of the rear wiper not in the correct position, happened to me on my nbs these are the same design mechanically.
89Suburban
SE PA
I am going to investigate the wiring from the push button and the latch solenoid and see if they run into the wiper plug and if I can make any sense out of it or bypass it.
But I will plug the motor in first and test everything to confirm our theories and report back. Thanks for the help and brainstorming.
89Suburban
SE PA
Were you able to figure it out?
Working on it right now brah. Here is the wiring plugs. The blue and the pink with black stripe both go to the wiper motor. The red with white stripe on the wiper plug is power black is ground. If I run a jumper from the red/white to the blue the glass solenoid pops open. Really need a wire diagram.
89Suburban
SE PA
Pin
Wire Color
Circuit No.
Function
L-BU
6795
Liftglass/Trunk Motor Release Control 2
BK
1450
Ground
BK
1450
Ground
PK/BK
1303
Liftgate Ajar Switch Signal (E52 Except E61)
PU
2279
Liftglass Ajar Switch Signal (E61)
89Suburban
SE PA
Ok when I run this jumper from tan to blue on the wiper plug it works. The button and the key fob open the glass. Not sure what to do with the pink/black wire for the glass ajar signal.
Do you get the window ajar message? If so maybe try putting a jumper from the pink/blk to ground--maybe that'll kill the signal?
89Suburban
SE PA
Nah I think it’s all good man. Warning only comes on when it should. Tailgate open or glass open. No warning when all is closed. I think I got it. :)
Korbin_A
