BlackedOutHoe
Low & Slow
Thank you!
Gonna read up now...
No problem! I stumbled upon it Friday. I'm definitely intrigued and compelled to try, but I'm curious mostly if when you stop adding the MPG will fall back to normal.
Thank you!
I doubt it. I don't see how it could make any drastic change in MPG in the first place unless your system was already ailing. I've been using it for a few months now, both before and after the engine mods. I noticed smoother idling after a few weeks of running it. I'd attribute that to my injectors being slightly dirty and the oil gradually cleaned them.
At midnight? yeah everyone goes slow. Major speed trap area. Admittedly I was the slowest on the road but only by about 2mph. Going 60 was more about having an easily repeatable test than anything else. Somewhere back in this thread, I did a little straight shot with similar conditions when I was testing if fuel system cleaners had any effect. Tried to find it but I suck at using the search function.Link to thread?
Does everyone drive that slowly up there on the freeway? Speed limit signs mean absolutely nothing here, not even to the cops. They have a saying: "19 is fine, but 20- you're mine".
My questions are:
A- How often do you add it?
B- The moment you stop adding it, does your MPG drop off and go back to the typical 14-16?
Could also speculate about ring to cylinder wall friction. 8 cylinders can add up to some drag. Can't comment on injectors as the last time I had them out was when I was changing my intake manifold gasket. Didn't really look at them or do a spray test. Was just swapping o-ringsI doubt it. I don't see how it could make any drastic change in MPG in the first place unless your system was already ailing. I've been using it for a few months now, both before and after the engine mods. I noticed smoother idling after a few weeks of running it. I'd attribute that to my injectors being slightly dirty and the oil gradually cleaned them.
That stupid rabbit holes I go down....
Y'all remember the thread about the dude adding oil to his gas and posting some dumb fuel economy numbers?
TWC3 rated 2 stroke 450-500:1 mix.
Could probably squeeze a few more tenths if there was anything on this vehicle that was fuel economy conscious.... 4wd (driven in 2wd), 75w140 in the Diffs, no fuel saver stuff in the trans, high pressure oil pump, and smoker shades on the windows.
Held at 60mph as per GPS. 60f ambient, no a/c. Flat enough freeway. Roughly 13mi
I was waiting until I put the boss plow frame on and tow hooks back to post pics of completed look.No pics..? You know the drill
So you responded to my no pics post with.. no pics, and saying you were waiting until you had the plow frame and tow.. ah... Did I miss the pics??I was waiting until I put the boss plow frame on and tow hooks back to post pics of completed look.
x2So you responded to my no pics post with.. no pics, and saying you were waiting until you had the plow frame and tow.. ah... Did I miss the pics??
I unbolted part of the seats, shoved a crow bar under the carpet and fished the wires thru with a coat hangerA lot of work zero progress only thing I actually got done was running the RCA's and the remote turn on for the amplifier under the carpet completely forgot to run the remote volume so zero progress
View attachment 254679 View attachment 254680
Are they powerfold?Did an oil and filter change and tire rotation.
Broke the passenger side mirror when trying to manually fold it. Now it's really loose and folds back and forth easily
Nope, manual fold, heated.Are they powerfold?
If it was hard to fold before but is easy now did you break it or improve it?![]()
well now it will fold while driving down the road and the wind pushed against it, so I guess it's now a wind fold mirror...lol
