Here’s some fuel for the fire. There’s a whole lot of threads out there that swear the fluid with GM’s spec GL-5 already has the LS additive in it. This is from Bob Is The Oil Guy’s website. I’m not saying it’s accurate but this is part of the reason there’s so much confusion, and I never could get to the bottom of it. All I know is I use AC Delco synthetic fluid spec’d for the G80 so I don’t have to look up any more confusing info. Does it have the LS additive in it? I do not know. I just know it doesn’t need anything added lol. Quote:
Originally Posted By: dnewton
Regardless of what others state, the G-80 does have clutches. They often mistakenly think that the "locker" is a mechanical type, but it is actually a pawl-operated clutch system. It has clutches. You need LS additive if you have a G-80.
I can confirm that the G80 is a clutch based system -- just had them replaced in my daughter's '03 Sierra -- in case that helps.
