ivin74
05 NBS Nali
I wanted to put this on its own thread because I’ve done some work and still more to do.
First thing was to fix the issues that I know about. The stalling in gear was only a dirty throttle body. I removed the throttle body, bypassed the coolant that goes through the TB with a barbed fitting and also cleaned the MAF sensor.
Replaced the passenger window motor and track. That was only $42 from Amazon and an easy swap. While I had the window out I removed the tint and put on some 5% ceramic tint. Then I also did the drivers side with the same. I’ll address the rear windows soon. The tint job was terrible thats why I had to change it.
The center console lid was just a $12 part off eBay. I pulled that apart and put in the new latch.
The tire was a leaking valve stem at the rim. Took the tire off and dropped it off at Firestone and had them swap that out for me. $30.
The ac was only a leaky high pressure fitting. $3 part and some time evacuating the system, pulled 28” vacuum on it for 40 minutes then added some pag oil and 3lbs of freon. Blow cold and haven’t had an issue since.
I also replaced the fog lights because the lenses were yellow and one had a crack in it.
There’s also a broken exhaust manifold bolt and it ticks when it’s cold. Drives me crazy. So I ordered the parts but have yet to dig into it. These are the best manifold gaskets and I won’t use anything but these.
Then I addressed the dim yellow headlights. The lenses could use a good cleaning too but I needed more lighting so I ordered these LEDs.
Congrats on the new ride, looks like you know the nbs very well. Hope your son enjoys it.
