Was wondering how OP did the swap. Driveway with hand tools and hoist?
Oh yeah, me too!
Oh yeah, me too!
More and more I am just leaning on doing this in my driveway. Looks like you just remove exhaust, unbolt transmission, remove wiring/hosing to engine, remove motor mount bolts, remove radiator and support? Then yank it out?
Just curious if there are any gotchas and if it can be done in a reasonable time (say 2 days).
Ok so you remove and installed it without heads and intake? Honestly that sounds easier if you're doing it alone anyway.
I did the DOD delete myself over 2 days and the cleaning was the longest part. Putting the heads on and bolting down would be like 30 minutes if everything was cleaned already.
Seems less chance of ******* something up just doing the block alone. Probably longer time, but less stress for sure.
Affirmative. Main reason was access to the top four bellhousing bolts. The engine can be pulled with the mounts still bolted to it and radiator in place. Just pull the fans and turn the engine sideways. The mounts clear the core support and cowl by about 1/2".
That’s what I was thinking too.That's awesome. So nothing on the front clip has to be pulled at all?
Mine was mostly just a simple swap. Leave the front of the truck on and plenum off. No exhaust bolts broke thanks to a good soak. Very worth while swap, better MPG and the L9h has some good power.
There is a good deal on a 1K mile L9H for 3500 if interested in Rochester NY .
Heres the Facebook ad. I have no connection with the seller and have contacted him for his number. When he responds I will forward his number.Link?
"2009 L9H 6.2L engine Was just installed in this 09 Escalade at the dealer Factory crate engine under 1000 miles no damage to engine at all Have video of it running Can do it complete with harness and computers or just the long block Don't bother with low ball offers Engine is still in the truck it you want to hear it locally Will ship on your dime"
Thinking of swapping in ZL1
Should torque converter be swapped while down there or nah?
If it's in the budget, I would. Nothing crazy, though. 5-6 hundred RPM makes a big difference, even on a stock motor. If camming, a looser converter may be even more helpful dependent upon that cam. There are a lot of factors that you have to honestly weigh, though.
Do you tow? How much weight?
