2009 gmc yukon denali l9h 6l80 driveability issue
Nando2724
I have a 2009 gmc yukon denali L9H 6l80 with 175k miles. I have p0016 that randomly goes active . Drves and shifts perfectly fine except once it is at operating temp and only when deceleration the engine begins to stutter and bog down and feels like it is misfiring. But i have no miss fire registering. I have verified all grounds and wiring harness are good. I recently replace timing chain and tensioner vvt actuator and phaser and camshaft and crankshaft sensors due to synchronization fault code p0016. I'm at the end of my rope and need any and all suggestions
rdezs
1. Did you perform the CASE relearn with a Tech 2 or bidirectional scanner?
2. Were the phaser, actuator, crank and cam sensors genuine GM or ACDelco? (Aftermarket on the crank and cam sensors can be problematic.)
3. Did you install a new timing chain sprockets along with the chain?
4. And I'm assuming after you installed and set the timing chain correctly, you rotated the engine over by hand a couple times and verified the timing marks still lined up?
5. After assembly of the timing chain and gears, did you confirm 0.001 camshaft end play?
6. What's your oil pressure at a hot idle?
7. And I'm assuming you installed a new oil pump since you had it off? And if so, which oil pump did you use?
Welcome to the Forum from NH.
Pics of the truck, please.
You are already receiving clarifying questions from the knowledgeable folks on this Forum. We will help you get through this issue.
B-train
Doing a Bump on this thread. I just experienced the P0016 and P0506 codes after pulling off the freeway. The truck stumbled and had no power. Pushing the gas pedal didn't do much and then it revved up and then eventually went back to the low, stumbling idle. I let it sit for a couple hours, checked the codes - stated above - and then drove it. Seems to run just fine.
After viewing some videos about the code, it leads towards timing chain, tensioner, etc. It is hot as hell today, so maybe it's a flaky sensor with heat? Or I'm in for a bigger project. Truck is 2008 Yukon, 6.2L, 203k miles. Unfortunately I don't have a Tech2, but do have access to a snap-on bi-directional scanner if needed.
Conedaddy
