Bear77
South FL
Should help. Do a few coats. I can't believe the body shop let you go without saying what could happen to the bondo when there's long term exposure to water or moisture.
When you don’t know...
Sam Harris
Have the combustion chambers brought down to around 63cc and run thinner gaskets and you'll regain any TQ lost from the cam. You'll gain power across the board, not just down low. I like 10.5:1 CR as a minimum. Also, while the heads are off, have the bowls blended in. Smoothing the casting in the runners and refining the hump around the valve guide are easy but effective little mods.
If you find a deal on some, get 243 or 799 heads and do all of the above. You'll be starting with a better design and larger intake valve to complement a cam.
If you know for sure you'll be boosting, then disregard raising the CR.
This is great info. Thank you!
05Single
afraid of the dark
In other news : Dude on Instagram sold his rare clear tail lights. $20 a ticket with 1500 raffle spots. So basically sold them for $3k lol. But the winner got them for $20 (might have had a couple spots but still these go for 400 all day used) .
Should’ve did that with my clear corners:hmm:
Got my truck back from body shop that was fixing the holes that were in the roof. Started installing Esky roof rack!
Also pictured are the wheels that I’m looking to get center caps for.
usually wheels have the model number stamped on the backside, take a wheel off and write down the numbers off the backside, one set will probably be the size, etc but one should be a model number then maybe google that +wheel and maybe you will get lucky.
Should’ve did that with my clear corners:hmm:View attachment 250881
Ingenuous!!
Bear77
South FL
I’ll take a look tomorrow. Thanks for this great information! Will most likely do it after I go to the post office in the morning and tell them a thing or three about themselves!
treehan77
TYF Fiend
Crestview, FL
Danny3737
Had to replace the driver side view mirror glass after breaking it backing out of my new garage. Went OEM since it’s got the auto dimming etc. The first one I got was defective and looked like a fun house mirror. The second one was perfect. I can guarantee that won’t happen again.
BBB129
