GJones
ATL
Before I bought mine from @ScottyBoy, I had bought a new aftermarket harness from one of those companies that sells them--forget which--but once I started getting and reading feedback about the aftermarkets, I sold it. Def don't want an important part such as that failing on you at the worst moment, possibly ruining your motor. Or worse, your truck catching on fire.
From my quick search at work the latest I’ve seen about them being bad was 2015. But I definitely got mot searching to do.
Not that it really makes a difference, but this is the company's harness I went with. It looks really good, labeled and everything. But look at the gauge wiring, along with the complete package. Compare it to oem. Stick with oem.
Sam Harris
Recorded a cold start video, post-BBP tune:
Now I REALLY want my cam... [emoji16][emoji631]
Trying to decide if I want to replace heads or not.. I was planning to get a BTR or TSP stage 2 cam, but don’t want to lose any low end tq. And I think any stage 2 has that consequence even a slight loss. [emoji53] so either getting springs and cam, or a whole head set. Eventually I’d like to SC her, but I need to get a plan together for the pieces I need to assemble.
Sounds like you have a small cam in there already! Sounds good. Stock exhaust?
Sounds good Sam!
Got my truck back from body shop that was fixing the holes that were in the roof. Started installing Esky roof rack!
Also pictured are the wheels that I’m looking to get center caps for.
How'd they fix it, and was it expensive? Come out good?
Dud you try the company's website for the center caps? Missing one?
Bear77
South FL
I’m not sure, really don’t know anything about body work except from what I recently learned from @Rocketman and to remove and replace parts! As for the wheels, I have no idea who made these, so it’s been a mission trying to find the center caps. But not going to give up until I find out!
