George B
¯\_(ツ)_/¯
Oconomowoc, Wisconsin 53066
$7.00 wireless charging upgrade. Pretty slick.
image.jpg 3F11D7FE-9B63-49EA-8A64-A0F041574C7D.jpeg 4D3DDC31-E0FA-4BCF-A1C2-CB498AF5EC47.jpeg D47B6EA9-4C57-45FD-ACC3-1B0350ED0EF0.jpeg image.jpg
George B
¯\_(ツ)_/¯
What is there, a power socket on the inside there??? :confused:
I had to make a little pad to hold the charger up tight to the tray so I used some closed cell packing sheet.
there is a usb port in there that connects to the head unit for loading and playing music. I have a memory stick full of songs but navigating the list in the head unit is awkward. I primarily stream pandora through bluetooth using the aux port so it was cleaner to grab my power there. There is a cig socket right under it too if needed but the usb is controlled by key on.
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
That's pretty sweet, did you do a work thread on that?
PPV12HOE
NC
is the rear wiper arm working? if the wiper arm is not parked in the resting slot properly the rear glass will not open, try operating the rear wiper and then try the glass again
Wiper works fine...
Haven't done it yet but I picked up 2 new Interstate AGM's, pretty sure one of the odyssey is done for and the other is a year newer so going to start fresh with 2 of the same age, going to get a new ground cable made up tomorrow so both battery's are connected to the rvc just because.....
took her for a 2.5 hour drive today avg 11.7mpg @90mph on mid-grade, trans temp was 165-180deg 100deg ambient temp elev 0-768ft
Hodmjstone
