Woodblocker55
- Joined
- Apr 13, 2019
- Posts
- 673
- Reaction score
- 422
Ok do I replace sensor under front pan or is there codes to go by ?
Sent from my LGL722DL using Tapatalk
Exactly.Know what you mean! Have the MX and now seems doesn’t want to connect
This was the reason why I got the MX but for some reason it just stopped working.Mine works fine, but it’s WiFi not Bluetooth. Bluetooth elm327 won’t work with iPhones.
It's been long enough. Firmware needed updating but then I got the command time out error and I tried reset that didn't work either. So had shoot off email. Joys of updating firmware. Must be something in reset I'm doing wrong .
Actually I cleaned the ground cables under the drivers door today and that cleared some of my electrical problems right away. Problem is they were rusted bad. My stereo died last fall, just today I heard the sweet sound of music from my Yukon today. Plus seems it fixed a few other things. Still have the odd problem but it makes it one less possibility. Oh when you clean those grounds under the driver's door the guy said to put undercoating on them so they don't rust again.Look at this code nightmare.. I'm hopping cleaning ground cables make some go away . lol![]()
I would be surprized if it didn't clear a bunch of those. My battery ground was at the front by the driving light. The two under the drivers door and the one I didn't get yet is the end by the engine block. The top firewall connection was easy. Had to use a dremell and it was great. Used a blue stone.Actually I cleaned the ground cables under the drivers door today and that cleared some of my electrical problems right away. Problem is they were rusted bad. My stereo died last fall, just today I heard the sweet sound of music from my Yukon today. Plus seems it fixed a few other things. Still have the odd problem but it makes it one less possibility. Oh when you clean those grounds under the driver's door the guy said to put undercoating on them so they don't rust again.
Sent from my CLT-L04 using Tapatalk
