89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
Do you just extract it from the reservoir and replace with new fluid or is there a drain in rhe rack somewhere?
2001 Yukon SLT
2012 Yukon Denali XL
2011 Yukon Denali RIP 5/20/18
This is how I did it so it’s just a partial change. Just did mine a few weeks ago too.
2001 Yukon SLT
You remove the return line from the reservoir and route it to a bucket, with the front suspension hanging, then turn the wheels side to side to pump all the fluid out. Then hook everything up, refill and bleed. There’s videos out there, maybe @iamdub can link one.
2001 Yukon SLT
that's what I did I just taped one end of the pump line to a milk jug so it wouldn't pop out mid pump and make a big mess, once it was empty I just refill it, I jacked up the front just so the wheels are off the ground and start it up and turn it lock to lock about 5 times and repeat, takes about a gallon to get it all "clear" again if you haven't ever done it, I did it last April the first time and I assume it had never been done so that fluid was about 7 years old, this time since it has only been about a year I could have got away with doing about 3 quarts it was coming out pretty clear but I went ahead just did almost the full gallon. use lots of rags it's basically mineral oil it reportedly will eat paint so just wipe up whatever gets spilled right away kind of hard to not get it everywhere when it's dripping off the pump tube inside and out.
New headlight switch, super easy just pops in/out like a Lego, lol no tools needed
**I take that back I did use a little flathead screwdriver tip from my pocket knife to lift the switch tabs a hair to pop the switch out after that the new one just snaps back in place
This is exactly how I do it. I watch for it to start sputtering, shut it off, add more fluid, start it back up and repeat. Usually takes about a full wasted gallon before what's coming out looks identical to what's going in.
Here's the first video I Googled. This Hotel WiFi is kinda slow, so I just skimmed through it. Not totally sure of the content/relevance:
If you pull the return line off and stick it in a bucket ( I added extra line so it reached the ground) you get it all out, but just be sure to keep it topped off. When the fluid turns clear you have done a full exchange. Here’s a great YouTube video on it.
5strmtrp
View attachment 248258 This. Again. Chasing a wiring gremlin.
Holy crap, that’s almost as sucky as me trying to get a bathroom ceiling wall smooth after redoing just the shower area! Sorry man feel your pain! The song Bullet to the head comes to mind!
I did that once on my Sonoma, 3 weeks of nope not that one, wait no, check the next one. No fun at all.
Hope it’s smoother for you.
Paul
5trmtpr
5strmtrp
Tozan and I are trying to figure out how to put a switch on the inside of our trucks to release the tailgate from the inside. He has a great setup in his rig for camping, attempting to do the same for us here. His whole link is on the suspension section. Frigging awesome stuff.
Paul
5trmtpr
Paul
5trmtpr
I take yours does not have the overhead console switch? not sure how much plug-n-play it would take but you can buy the console portion on ebay for about $50 with the switch, then I guess wire it up? mine has the denali trim but I would assume they all would have the inside button on the side kickpanel in the back
osiris94ej
Casper Wyoming
Deennoek
